주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation)
필요한 것
    1. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disassembly: 1 단계, 이미지 3개 중 1개 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disassembly: 1 단계, 이미지 3개 중 2개 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disassembly: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • You will need to leave your Kindle powered on but in sleep mode.
      • If it has run out of power, you may want to plug it in first to ensure that the display is still intact and not cracked.
      • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
      • You may need plastic cards in between the bezel and rear cover if the former keeps sticking back down while you attempt to pry it up.
      • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
      댓글 쓰기
    2. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): 2 단계, 이미지 2개 중 1개 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): 2 단계, 이미지 2개 중 2개
      • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
      댓글 쓰기
    3. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): 3 단계, 이미지 1개 중 1개
      • Gently lift the mid-frame out of the case with your hands.
      댓글 쓰기
    4. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disconnecting the Frontlight: 4 단계, 이미지 3개 중 1개 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disconnecting the Frontlight: 4 단계, 이미지 3개 중 2개 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disconnecting the Frontlight: 4 단계, 이미지 3개 중 3개
      • Now comes the hard part.
      • Your Kindle may not respond to the power button, and disconnecting the frontlight at this point will leave it in that unusable state.
      • Tap on or bring a magnet close to the hall effect sensor.
      • When the frontlight lights up, immediately unplug its connector.
      • If your Kindle remains awake for more than 3 seconds, you may now put it back to sleep by pressing the power button.
      • If not, you may have to repeat this step.
      댓글 쓰기
    5. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): 5 단계, 이미지 3개 중 1개 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): 5 단계, 이미지 3개 중 2개 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): 5 단계, 이미지 3개 중 3개
      • You will then need to cover pins 2 and 4 of the front light connector.
      • Cut a small piece of electrical tape that is thin enough to cover both pins, and apply it.
      • Reconnect the frontlight.
      • Be careful to not block pin 6 and/or any other pins, as it may result in the frontlight not receiving power and/or the device re-entering the closed cover state.
      댓글 쓰기
결론
To reassemble your device, follow steps 1-3 in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kevin Bhasi
회원 가입일: 12/26/14
1,355 평판
안내서 9개를 작성함
3가이드 댓글
Brilliant! I just went through the process of disconnecting my hall sensor harness to fix an intermittent wake/lock issue. It worked, but i didn’t realize I’d nerfed the backlights until after getting it all reassembled. Thankfully found this guide and it worked perfectly.
Daniel Swick - 답글 공유
Cover sensor was malfunctioning after a battery replacement so I followed your guide and it worked wonderfully! Hope to get another 8 years from this thing instead of dropping it in a landfill! Thanks
Andrew McDonnell - 답글 공유
Very clever! Thank you. In the event, changing the battery on my 7th generation Kindle Paperwhite seems to have fixed the problem with the cover sensor. That triggered a hard reset, so it might be worth trying that before continuing with this mod.
Charles Butcher - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 119
전체 시간: 5,536
