주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling APEX AP-GS918 Screen
필요한 것
    1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: 1 단계, 이미지 3개 중 1개 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 1 단계, 이미지 3개 중 2개 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 1 단계, 이미지 3개 중 3개
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      댓글 쓰기
    2. Disassembling APEX AP-GS918 Screen: 2 단계, 이미지 3개 중 1개 Disassembling APEX AP-GS918 Screen: 2 단계, 이미지 3개 중 2개 Disassembling APEX AP-GS918 Screen: 2 단계, 이미지 3개 중 3개
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      댓글 쓰기
    3. Disassembling APEX AP-GS918 Screen: 3 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      댓글 쓰기
    1. Disassembling APEX AP-GS918 Screen, Battery: 4 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen, Battery: 4 단계, 이미지 2개 중 2개
      • Begin removing the black tape covering the motherboard inside the tablet.
      댓글 쓰기
    2. Disassembling APEX AP-GS918 Screen: 5 단계, 이미지 1개 중 1개
      • You will need to desolder the two contact points that connect the battery to the mother board.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      댓글 쓰기
    3. Disassembling APEX AP-GS918 Screen: 6 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 6 단계, 이미지 2개 중 2개
      • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
      • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
      댓글 쓰기
    1. Disassembling APEX AP-GS918 Screen, Screen: 7 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen, Screen: 7 단계, 이미지 2개 중 2개
      • The motherboard will need to be removed in order to access the screen.
      • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
      댓글 쓰기
    2. Disassembling APEX AP-GS918 Screen: 8 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 8 단계, 이미지 2개 중 2개
      • To finish removing the motherboard you must release the two data cables holding the screen to it.
      • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
      • You can now remove the data cables from the slots and lift the motherboard out from the device.
      댓글 쓰기
    3. Disassembling APEX AP-GS918 Screen: 9 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 9 단계, 이미지 2개 중 2개
      • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
      댓글 쓰기
    4. Disassembling APEX AP-GS918 Screen: 10 단계, 이미지 1개 중 1개
      • Pull the thin plastic screen casing apart and you can remove the damaged screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Megan Lozicki
회원 가입일: 02/19/15
416 평판
안내서 4개를 작성함
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G1
3 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 33
전체 시간: 1,009
