주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling APEX AP-GS918 Screen
필요한 것
  1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: 1 단계, 이미지 3개 중 1개 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 1 단계, 이미지 3개 중 2개 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 1 단계, 이미지 3개 중 3개
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. Disassembling APEX AP-GS918 Screen: 2 단계, 이미지 3개 중 1개 Disassembling APEX AP-GS918 Screen: 2 단계, 이미지 3개 중 2개 Disassembling APEX AP-GS918 Screen: 2 단계, 이미지 3개 중 3개
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. Disassembling APEX AP-GS918 Screen: 3 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. Disassembling APEX AP-GS918 Screen, Battery: 4 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen, Battery: 4 단계, 이미지 2개 중 2개
    • Begin removing the black tape covering the motherboard inside the tablet.
  5. Disassembling APEX AP-GS918 Screen: 5 단계, 이미지 1개 중 1개
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
  6. Disassembling APEX AP-GS918 Screen: 6 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 6 단계, 이미지 2개 중 2개
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
  7. Disassembling APEX AP-GS918 Screen, Screen: 7 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen, Screen: 7 단계, 이미지 2개 중 2개
    • The motherboard will need to be removed in order to access the screen.
    • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
  8. Disassembling APEX AP-GS918 Screen: 8 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 8 단계, 이미지 2개 중 2개
    • To finish removing the motherboard you must release the two data cables holding the screen to it.
    • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
    • You can now remove the data cables from the slots and lift the motherboard out from the device.
  9. Disassembling APEX AP-GS918 Screen: 9 단계, 이미지 2개 중 1개 Disassembling APEX AP-GS918 Screen: 9 단계, 이미지 2개 중 2개
    • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
  10. Disassembling APEX AP-GS918 Screen: 10 단계, 이미지 1개 중 1개
    • Pull the thin plastic screen casing apart and you can remove the damaged screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Megan Lozicki
회원 가입일: 02/19/15
416 평판
안내서 4개를 작성함
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G1
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 77
전체 시간: 895
