주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Ableton Move Backplate
  1. Disassembling Ableton Move Backplate, Remove visible screws: 1 단계, 이미지 1개 중 1개
    • First unscrew the 4 accessible screws on the bottom of the unit
    댓글 쓰기
  2. Disassembling Ableton Move Backplate, Remove hidden screws: 2 단계, 이미지 1개 중 1개
    • There are 4 more screws here. To access them, you need peel off the rubber pads. If you are careful, you can get away with not peeling them off completely. In this image, the purple areas mark the areas that I found relatively "safe" to peel off to be able to get access to the screws but also allowed to gently push the pads back on.
    댓글 쓰기
  3. Disassembling Ableton Move Backplate, That's it.: 3 단계, 이미지 1개 중 1개
    • After removing the screws under the rubber pads, the backplate should gently fall off under it's own weight. If not, help a little with plastic opening tools.
    • Now you have access to the SD card, the raspberry pi 4 compute module, the Intel WiFi Chip, the battery, and the builtin 8 Ohm 2W speakers.
    • Taking apart the unit further than this holds the risk of damaging it significantly, so only progress with lots of caution.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
losferatu
회원 가입일: 10/30/24
194 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 54
전체 시간: 531
