주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Antsle One D Server
필요한 것
  1. Disassembling Antsle One D Server, Remove Front Plate: 1 단계, 이미지 3개 중 1개 Disassembling Antsle One D Server, Remove Front Plate: 1 단계, 이미지 3개 중 2개 Disassembling Antsle One D Server, Remove Front Plate: 1 단계, 이미지 3개 중 3개
    • Remove the screws from the front panel.
    • There are also two screws in the front bottom of the plate that need to be removed.
    • When pulling the plate away from the body, be careful as a spring is keeping the silver button in place. The spring also easily slips off the button. Keep an eye out so you don't lose either of these items.
    댓글 쓰기
  2. Disassembling Antsle One D Server, Remove bottom plate: 2 단계, 이미지 2개 중 1개 Disassembling Antsle One D Server, Remove bottom plate: 2 단계, 이미지 2개 중 2개
    • To remove the bottom plate, remove the four-foot screws and the two screws from the rear plate, and the bottom will slide out.
    댓글 쓰기
  3. Disassembling Antsle One D Server, Remove Back Plate: 3 단계, 이미지 1개 중 1개
    • Remove the four screws from the rear plate
    • Unscrew the DC input connector
    • After, completing the previous step, and these six screws are removed, you can safely detach the rear plate.
    댓글 쓰기
  4. Disassembling Antsle One D Server, Remove Front Panel PCB: 4 단계, 이미지 1개 중 1개
    • Remove the two screws keeping the PCB mounted
    • Disconnect the power cable.
    댓글 쓰기
  5. Disassembling Antsle One D Server, Remove the hard drive bay: 5 단계, 이미지 2개 중 1개 Disassembling Antsle One D Server, Remove the hard drive bay: 5 단계, 이미지 2개 중 2개
    • Disconnect the power and SATA cables from the hard drives.
    • Remove the four screws keeping the hard drives in place.
    댓글 쓰기
  6. Disassembling Antsle One D Server, Remove the motherboard: 6 단계, 이미지 2개 중 1개 Disassembling Antsle One D Server, Remove the motherboard: 6 단계, 이미지 2개 중 2개
    • Remove the four internal screws keeping the CPU pressed against the heat sink (labeled orange).
    • Remove the four outer screws (labeled yellow).
    • Lift the motherboard away. The thermal paste may have good adhesion and additional gentle force may be needed to pry it away.
    댓글 쓰기
    • Out of the box, the Antsle One D comes with 2 SATA hard drives. These can be disconnected from the SATA ports.
    • The front panel PCB is connected via a <look up> wire.
    • A power connector goes from the DC input to the motherboard.
    • A <look up> connector goes from the motherboard to the hard drive bay.
    댓글 쓰기
  7. Disassembling Antsle One D Server, CPU & RAM: 8 단계, 이미지 2개 중 1개 Disassembling Antsle One D Server, CPU & RAM: 8 단계, 이미지 2개 중 2개
    • CPU - Intel C3558 SR388 2.20GHZ
    • RAM - DDR4 2666 RDIMM 1.2v CL19
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
fausty
회원 가입일: 06/16/24
725 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 41
전체 시간: 357
