주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Canon EOS 60D Removing Back Panel
필요한 것
    1. Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: 1 단계, 이미지 2개 중 1개 Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: 1 단계, 이미지 2개 중 2개
      • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
      • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
      댓글 쓰기
    2. Disassembling Canon EOS 60D Removing Back Panel: 2 단계, 이미지 2개 중 1개 Disassembling Canon EOS 60D Removing Back Panel: 2 단계, 이미지 2개 중 2개
      • Open the battery door
      • Rotate the door so the one side of the hinge pops out (see photo #2)
      • Slide other pin out (it pops out the same, but this is easier)
      댓글 쓰기
    1. Disassembling Canon EOS 60D Removing Back Panel, Rubber grips: 3 단계, 이미지 1개 중 1개
      • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
      • Repeat for the other two grips
      • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
      • The small one on the back is a bit difficult to get started, but not really difficult to remove.
      • The one on the AV panel will be easier if you open up the AV port cover.
      • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
      • Optionally throw the balled up adhesive at people pretending its a booger :)
      댓글 쓰기
    1. Disassembling Canon EOS 60D Removing Back Panel, Left-Side Port Cover: 4 단계, 이미지 1개 중 1개
      • Remove 3 screws
      댓글 쓰기
      • Remove the small Screw under the Flip cover too
      댓글 쓰기
    2. Disassembling Canon EOS 60D Removing Back Panel: 6 단계, 이미지 1개 중 1개
      • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
      • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
      • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
      댓글 쓰기
    3. Disassembling Canon EOS 60D Removing Back Panel: 7 단계, 이미지 1개 중 1개
      • Slide the rear part of the cover out.
      댓글 쓰기
    4. Disassembling Canon EOS 60D Removing Back Panel: 8 단계, 이미지 2개 중 1개 Disassembling Canon EOS 60D Removing Back Panel: 8 단계, 이미지 2개 중 2개
      • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
      • Slide down to remove without damaging the cover. (see photo with cover removed)
      • You can see how the cover, and side piece fit together in the second image.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eric D
회원 가입일: 11/13/12
1,377 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 48
전체 시간: 5,749
