주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Epson PPC650 Replacing Flash
필요한 것
  1. Disassembling Epson PPC650 Replacing Flash, Case: 1 단계, 이미지 3개 중 1개 Disassembling Epson PPC650 Replacing Flash, Case: 1 단계, 이미지 3개 중 2개 Disassembling Epson PPC650 Replacing Flash, Case: 1 단계, 이미지 3개 중 3개
    • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
    • Remove the batteries from the battery compartment located on the underside of the camera.
    • Remove the SD card from the compartment located on the flat, left side of the camera.
    댓글 쓰기
  2. Disassembling Epson PPC650 Replacing Flash: 2 단계, 이미지 1개 중 1개
    • Remove the two screws on the rounded side of the camera.
    댓글 쓰기
  3. Disassembling Epson PPC650 Replacing Flash: 3 단계, 이미지 2개 중 1개 Disassembling Epson PPC650 Replacing Flash: 3 단계, 이미지 2개 중 2개
    • Remove the three screws on the flat side of the camera.
    • All of the silver screws go into the side of the camera that is silver.
    • All of the black screws go into the side of the camera that is black.
    댓글 쓰기
  4. Disassembling Epson PPC650 Replacing Flash: 4 단계, 이미지 1개 중 1개
    • Remove the four screws from the bottom of the camera.
    댓글 쓰기
  5. Disassembling Epson PPC650 Replacing Flash: 5 단계, 이미지 3개 중 1개 Disassembling Epson PPC650 Replacing Flash: 5 단계, 이미지 3개 중 2개 Disassembling Epson PPC650 Replacing Flash: 5 단계, 이미지 3개 중 3개
    • Separate the front and the back pieces of the camera's plastic casing using a spudger.
    • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
    • Use minimal force so that the plastic casing does not break.
    • When separating the small silver siding, the indicator for the view/off/playback may fall out.
    • The plastic viewing window located on the top of the camera may also become lose and fall out.
    댓글 쓰기
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 6 단계, 이미지 3개 중 1개 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 6 단계, 이미지 3개 중 2개 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 6 단계, 이미지 3개 중 3개
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
    댓글 쓰기
  7. Disassembling Epson PPC650 Replacing Flash: 7 단계, 이미지 1개 중 1개
    • Remove clear rubber band holding flash in line with wiring.
    댓글 쓰기
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    댓글 쓰기
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Xan Danes
회원 가입일: 02/14/13
134 평판
안내서 1개를 작성함
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 29
전체 시간: 633
