주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Ericsson CF 388 Circuit Board
필요한 것
  1. Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 3개 중 3개
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
    댓글 쓰기
  2. Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 2 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 2 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 2 단계, 이미지 3개 중 3개
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
    댓글 쓰기
  3. Disassembling Ericsson CF 388 Circuit Board: 3 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Circuit Board: 3 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Circuit Board: 3 단계, 이미지 3개 중 3개
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
    댓글 쓰기
  4. Disassembling Ericsson CF 388 Circuit Board: 4 단계, 이미지 2개 중 1개 Disassembling Ericsson CF 388 Circuit Board: 4 단계, 이미지 2개 중 2개
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
    댓글 쓰기
  5. Disassembling Ericsson CF 388 Circuit Board, Circuit Board: 5 단계, 이미지 1개 중 1개
    • Locate the circuit board on the rear side of the front phone casing (right side of image).
    • Locate the mounting screws (indicated by red circles), which attach the board to the rear side of the front phone casing.
    댓글 쓰기
  6. Disassembling Ericsson CF 388 Circuit Board: 6 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Circuit Board: 6 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Circuit Board: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws. Hold the back part of the screw with the metal tweezers.
    댓글 쓰기
  7. Disassembling Ericsson CF 388 Circuit Board: 7 단계, 이미지 2개 중 1개 Disassembling Ericsson CF 388 Circuit Board: 7 단계, 이미지 2개 중 2개
    • Completely remove the two center screw as shown.
    • Note: the hand not holding the screw driver is holding the back part of the screw and the panel in place.
    댓글 쓰기
  8. Disassembling Ericsson CF 388 Circuit Board: 8 단계, 이미지 2개 중 1개 Disassembling Ericsson CF 388 Circuit Board: 8 단계, 이미지 2개 중 2개
    • Locate the final screw at the top of the phone near the antenna, as shown by the red circle.
    • Using the U-shaped screw driver, remove the top screw.
    댓글 쓰기
  9. Disassembling Ericsson CF 388 Circuit Board: 9 단계, 이미지 2개 중 1개 Disassembling Ericsson CF 388 Circuit Board: 9 단계, 이미지 2개 중 2개
    • With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Niccolas Tones
회원 가입일: 03/09/12
60 평판
안내서 9개를 작성함
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 회원
CLEM-BENSON-S12S1G1
3 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 42
전체 시간: 1,660
