주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Ericsson CF 388 Speaker
필요한 것
  1. Disassembling Ericsson CF 388 Speaker, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Speaker, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Speaker, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 3개 중 3개
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
    댓글 쓰기
  2. Disassembling Ericsson CF 388 Speaker, Phone Casing: 2 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Speaker, Phone Casing: 2 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Speaker, Phone Casing: 2 단계, 이미지 3개 중 3개
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
    댓글 쓰기
  3. Disassembling Ericsson CF 388 Speaker: 3 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Speaker: 3 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Speaker: 3 단계, 이미지 3개 중 3개
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
    댓글 쓰기
  4. Disassembling Ericsson CF 388 Speaker: 4 단계, 이미지 2개 중 1개 Disassembling Ericsson CF 388 Speaker: 4 단계, 이미지 2개 중 2개
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
    댓글 쓰기
  5. Disassembling Ericsson CF 388 Speaker, Keypad Support Skeleton: 5 단계, 이미지 2개 중 1개 Disassembling Ericsson CF 388 Speaker, Keypad Support Skeleton: 5 단계, 이미지 2개 중 2개
    • After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
    댓글 쓰기
  6. Disassembling Ericsson CF 388 Speaker: 6 단계, 이미지 3개 중 1개 Disassembling Ericsson CF 388 Speaker: 6 단계, 이미지 3개 중 2개 Disassembling Ericsson CF 388 Speaker: 6 단계, 이미지 3개 중 3개
    • To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen.
    • Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
    댓글 쓰기
  7. Disassembling Ericsson CF 388 Speaker, Speaker: 7 단계, 이미지 1개 중 1개
    • Although it is not completely necessary, removing the plastic keypad skeleton structure helps with the ease of removing the speaker.
    • Locate the speaker at the top of the phone, above the LCD display screen, as shown by the red circle.
    댓글 쓰기
  8. Disassembling Ericsson CF 388 Speaker: 8 단계, 이미지 2개 중 1개 Disassembling Ericsson CF 388 Speaker: 8 단계, 이미지 2개 중 2개
    • To remove the speaker, gently place a plastic pryer tool underneath the speaker.
    • Carefully, lift up the pryer tool to remove the speaker from the adhesive glue connecting to the phone casing.
    • Note: it is preferred to slowly remove the speaker so the speaker is not flung or damaged. Easy does it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Niccolas Tones
회원 가입일: 03/09/12
60 평판
안내서 9개를 작성함
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 회원
CLEM-BENSON-S12S1G1
3 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 38
전체 시간: 1,394
