주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Flashlight Light Bulb Components
    1. Disassembling Flashlight Light Bulb Components, Disassembling Flashlight Light Bulb Components: 1 단계, 이미지 2개 중 1개 Disassembling Flashlight Light Bulb Components, Disassembling Flashlight Light Bulb Components: 1 단계, 이미지 2개 중 2개
      • The translucent flashlight before reverse analysis.
      • Twist the light components(red circle) counterclockwise while holding the body of the flashlight (black circle).
      댓글 쓰기
    2. Disassembling Flashlight Light Bulb Components: 2 단계, 이미지 3개 중 1개 Disassembling Flashlight Light Bulb Components: 2 단계, 이미지 3개 중 2개 Disassembling Flashlight Light Bulb Components: 2 단계, 이미지 3개 중 3개
      • When removing light component, the black rubber band (red circle) separating body and head falls off. Turn black socket (black circle), which connects bulb to batteries, counterclockwise and disconnect.
      • Bulb (red circle) simply pulled out reflector and lens compartment.
      • The metal connector (red circle) easily slides out open end when twisting off the black socket. This metal piece connects the metal switch supplying power to the bulb.
      댓글 쓰기
    3. Disassembling Flashlight Light Bulb Components: 3 단계, 이미지 2개 중 1개 Disassembling Flashlight Light Bulb Components: 3 단계, 이미지 2개 중 2개
      • The lens connected to the head of the flashlight comes apart using one thumb/finger. Using two other fingers to hold the head's base, the third thumb/finger pushes the lens in the opposite direction with a force >5N.
      • The remaining lens and light reflector component (red circle) of the flashlight pops out of the unit and separates. Simultaneously, the translucent skin (black circle) attached to the head of the flashlight peels off using hands.
      댓글 쓰기
    4. Disassembling Flashlight Light Bulb Components: 4 단계, 이미지 1개 중 1개
      • The complete light bulb component disassembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Phillip Phung
회원 가입일: 01/19/12
666 평판
안내서 9개를 작성함
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 회원
CPSU-MANESS-W12S8G18
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 36
지난 30일: 127
전체 시간: 6,629
