주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Flip Video Circuit Board
필요한 것
    1. Disassembling Flip Video Circuit Board, Outer Shell: 1 단계, 이미지 2개 중 1개 Disassembling Flip Video Circuit Board, Outer Shell: 1 단계, 이미지 2개 중 2개
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      댓글 쓰기
    2. Disassembling Flip Video Circuit Board: 2 단계, 이미지 1개 중 1개
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      댓글 쓰기
    3. Disassembling Flip Video Circuit Board: 3 단계, 이미지 2개 중 1개 Disassembling Flip Video Circuit Board: 3 단계, 이미지 2개 중 2개
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      댓글 쓰기
    4. Disassembling Flip Video Circuit Board: 4 단계, 이미지 1개 중 1개
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      댓글 쓰기
    5. Disassembling Flip Video Circuit Board: 5 단계, 이미지 1개 중 1개
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      댓글 쓰기
    1. Disassembling Flip Video Circuit Board, Circuit Board: 6 단계, 이미지 1개 중 1개
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      댓글 쓰기
    2. Disassembling Flip Video Circuit Board: 7 단계, 이미지 1개 중 1개
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      댓글 쓰기
    3. Disassembling Flip Video Circuit Board: 8 단계, 이미지 1개 중 1개
      • Disconnect the USB port cable from the back side of the circuit board.
      댓글 쓰기
    4. Disassembling Flip Video Circuit Board: 9 단계, 이미지 1개 중 1개
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Elizabeth
회원 가입일: 04/15/10
100 평판
안내서 6개를 작성함
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 회원
CPSU-REGAN-S10S26G21
4 회원들
안내서 18개를 작성함
1가이드 댓글
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 51
전체 시간: 2,756
