주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Flip Video USB Port
필요한 것
    1. Disassembling Flip Video USB Port, Outer Shell: 1 단계, 이미지 2개 중 1개 Disassembling Flip Video USB Port, Outer Shell: 1 단계, 이미지 2개 중 2개
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      댓글 쓰기
    2. Disassembling Flip Video USB Port: 2 단계, 이미지 1개 중 1개
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      댓글 쓰기
    3. Disassembling Flip Video USB Port: 3 단계, 이미지 2개 중 1개 Disassembling Flip Video USB Port: 3 단계, 이미지 2개 중 2개
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      댓글 쓰기
    4. Disassembling Flip Video USB Port: 4 단계, 이미지 1개 중 1개
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      댓글 쓰기
    5. Disassembling Flip Video USB Port: 5 단계, 이미지 1개 중 1개
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      댓글 쓰기
    1. Disassembling Flip Video USB Port, Circuit Board: 6 단계, 이미지 1개 중 1개
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      댓글 쓰기
    2. Disassembling Flip Video USB Port: 7 단계, 이미지 1개 중 1개
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      댓글 쓰기
    3. Disassembling Flip Video USB Port: 8 단계, 이미지 1개 중 1개
      • Disconnect the USB port cable from the back side of the circuit board.
      댓글 쓰기
    4. Disassembling Flip Video USB Port: 9 단계, 이미지 1개 중 1개
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      댓글 쓰기
    1. Disassembling Flip Video USB Port, USB Port: 10 단계, 이미지 1개 중 1개
      • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
      댓글 쓰기
    2. Disassembling Flip Video USB Port: 11 단계, 이미지 1개 중 1개
      • Lift wire out of the outer shell slot.
      • The wire mount should stay attached to the wire.
      댓글 쓰기
    3. Disassembling Flip Video USB Port: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to remove the spring that holds the port door shut.
      • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
      댓글 쓰기
    4. Disassembling Flip Video USB Port: 13 단계, 이미지 1개 중 1개
      • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
      댓글 쓰기
    5. Disassembling Flip Video USB Port: 14 단계, 이미지 1개 중 1개
      • Remove the USB port cover.
      댓글 쓰기
    6. Disassembling Flip Video USB Port: 15 단계, 이미지 1개 중 1개
      • Remove the USB slider.
      댓글 쓰기
    7. Disassembling Flip Video USB Port: 16 단계, 이미지 1개 중 1개
      • Lift out the USB port slowly.
      • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Elizabeth
회원 가입일: 04/15/10
100 평판
안내서 6개를 작성함
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 회원
CPSU-REGAN-S10S26G21
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 35
전체 시간: 4,523
