주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Garmin Nuvi 370 Into Core Components
필요한 것
    1. Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: 1 단계, 이미지 2개 중 1개 Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: 1 단계, 이미지 2개 중 2개
      • Unscrew the two screws on the antenna unit using a torc-head screwdriver.
      • The Torx-Head Screws' size is T-5, which is about 1.5mm.
      • Gently pry open the antenna unit with your fingers.
      • Be careful and try not to damage the small plastic tab.
      댓글 쓰기
    2. Disassembling Garmin Nuvi 370 Into Core Components: 2 단계, 이미지 3개 중 1개 Disassembling Garmin Nuvi 370 Into Core Components: 2 단계, 이미지 3개 중 2개 Disassembling Garmin Nuvi 370 Into Core Components: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Slide out the inner casing attached to the antenna body.
      • Remove the rotating joint connecting the antenna casing to the main device:
      • Squeeze tweezers into the shown location and compress the spring.
      • Lift out the outer casing while keeping the spring compressed.
      • watch out, as the spring loaded portion may fly out unexpectedly.
      댓글 쓰기
    3. Disassembling Garmin Nuvi 370 Into Core Components: 3 단계, 이미지 1개 중 1개
      • Using a torx-head screwdriver, unscrew the two revealed screws that connect the front and back of the device.
      댓글 쓰기
    4. Disassembling Garmin Nuvi 370 Into Core Components: 4 단계, 이미지 3개 중 1개 Disassembling Garmin Nuvi 370 Into Core Components: 4 단계, 이미지 3개 중 2개 Disassembling Garmin Nuvi 370 Into Core Components: 4 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool into the center of the edge as shown in first picture.
      • Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture.
      댓글 쓰기
    5. Disassembling Garmin Nuvi 370 Into Core Components: 5 단계, 이미지 3개 중 1개 Disassembling Garmin Nuvi 370 Into Core Components: 5 단계, 이미지 3개 중 2개 Disassembling Garmin Nuvi 370 Into Core Components: 5 단계, 이미지 3개 중 3개
      • Detach the front display from the back panel of the device.
      댓글 쓰기
    6. Disassembling Garmin Nuvi 370 Into Core Components: 6 단계, 이미지 2개 중 1개 Disassembling Garmin Nuvi 370 Into Core Components: 6 단계, 이미지 2개 중 2개
      • Using tweezers, gently lift the microphone from its resting position to fully separate the device into two parts.
      • Finally, remove the screw that connects the motherboard to the back casing with a 3mm head driver.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Robert
회원 가입일: 04/19/13
80 평판
안내서 1개를 작성함
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G65
3 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 42
전체 시간: 1,844
