주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling IBM WorkPad c3 Front Case
필요한 것
  1. Disassembling IBM WorkPad c3 Front Case, Back Case: 1 단계, 이미지 2개 중 1개 Disassembling IBM WorkPad c3 Front Case, Back Case: 1 단계, 이미지 2개 중 2개
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    댓글 쓰기
  2. Disassembling IBM WorkPad c3 Front Case: 2 단계, 이미지 1개 중 1개
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    댓글 쓰기
  3. Disassembling IBM WorkPad c3 Front Case: 3 단계, 이미지 2개 중 1개 Disassembling IBM WorkPad c3 Front Case: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    댓글 쓰기
  4. Disassembling IBM WorkPad c3 Front Case, Front Case: 4 단계, 이미지 2개 중 1개 Disassembling IBM WorkPad c3 Front Case, Front Case: 4 단계, 이미지 2개 중 2개
    • Turn the device over, so that the screen is laying on a flat surface.
    댓글 쓰기
  5. Disassembling IBM WorkPad c3 Front Case: 5 단계, 이미지 3개 중 1개 Disassembling IBM WorkPad c3 Front Case: 5 단계, 이미지 3개 중 2개 Disassembling IBM WorkPad c3 Front Case: 5 단계, 이미지 3개 중 3개
    • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
    • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
    • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
    댓글 쓰기
  6. Disassembling IBM WorkPad c3 Front Case: 6 단계, 이미지 2개 중 1개 Disassembling IBM WorkPad c3 Front Case: 6 단계, 이미지 2개 중 2개
    • The device will be extremely hot. Use a towel or oven mitt to grab it.
    • Using the Plastic Opening Tools, take the front of the case off.
    • If the case is difficult to remove, try repeating step 2.
    • The power button at the top of the device will be loose once the front part of the case is removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Emily Falkenstein
회원 가입일: 10/05/10
75 평판
안내서 5개를 작성함
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 회원
CPSU-REGAN-F10S21G35
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 2,948
