주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Kitchenware Rival Coffee Maker
필요한 것
    1. Disassembling Kitchenware Rival Coffee Maker, Rival Single Cup Coffee Maker: 1 단계, 이미지 1개 중 1개
      • Make sure the coffee maker is unplugged before proceeding.
      댓글 쓰기
    2. Disassembling Kitchenware Rival Coffee Maker, Unscrewing  Metal Base: 2 단계, 이미지 1개 중 1개
      • Locate and unscrew the 3 8mm Three-pronged Y screws at the bottom of the coffee maker base.
      댓글 쓰기
    3. Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: 3 단계, 이미지 3개 중 1개 Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: 3 단계, 이미지 3개 중 2개 Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: 3 단계, 이미지 3개 중 3개
      • Locate the white securing tab on the front rounded metal base. Push up on the plastic with the tip of your thumbs until the metal base is clear from the tab.
      • Remove the metal base from the coffee maker.
      댓글 쓰기
    4. Disassembling Kitchenware Rival Coffee Maker, Removing Power Cable Screws: 4 단계, 이미지 2개 중 1개 Disassembling Kitchenware Rival Coffee Maker, Removing Power Cable Screws: 4 단계, 이미지 2개 중 2개
      • Remove the two 13mm Phillips screws to release the power cord.
      • Remove the white cap from the screw holder.
      댓글 쓰기
    5. Disassembling Kitchenware Rival Coffee Maker, Removing Bottom Chassis Screws: 5 단계, 이미지 2개 중 1개 Disassembling Kitchenware Rival Coffee Maker, Removing Bottom Chassis Screws: 5 단계, 이미지 2개 중 2개
      • Remove the two 8mm Phillips screws from the metal chassis.
      • Remove the two black screw caps.
      댓글 쓰기
    6. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Power Button: 6 단계, 이미지 1개 중 1개
      • Remove the 7mm Phillips screw from the power button.
      댓글 쓰기
    7. Disassembling Kitchenware Rival Coffee Maker, Removing Power Button: 7 단계, 이미지 2개 중 1개 Disassembling Kitchenware Rival Coffee Maker, Removing Power Button: 7 단계, 이미지 2개 중 2개
      • Use a spudger or a flat head screwdriver to pull the white tab away from the power button body.
      • Pull the power button to the left of the tab until it is free from the tab. Then push the power button through the coffee makers body and let it sit inside the coffee makers body.
      댓글 쓰기
    8. Disassembling Kitchenware Rival Coffee Maker, Removing Power button from Cable: 8 단계, 이미지 1개 중 1개
      • Remove the 7mm Phillips screw from the motherboard of the power button.
      • Pull the white plastic body away from the logic board.
      댓글 쓰기
    9. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: 9 단계, 이미지 3개 중 1개 Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: 9 단계, 이미지 3개 중 2개 Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: 9 단계, 이미지 3개 중 3개
      • Remove the 4 13mm Phillips screws from the four corners of the case to release the bottom half of the coffee maker.
      • These screws are very deep and you may need a longer thinner screwdriver for it.
      댓글 쓰기
    10. Disassembling Kitchenware Rival Coffee Maker: 10 단계, 이미지 3개 중 1개 Disassembling Kitchenware Rival Coffee Maker: 10 단계, 이미지 3개 중 2개 Disassembling Kitchenware Rival Coffee Maker: 10 단계, 이미지 3개 중 3개
      • Tilt the bottom half of the coffee maker forward.
      • Pull up until it is free from the top half while feeding the power cable down through the plastic body.
      • Be gentle while removing the bottom half as the cables to the power button are very fragile.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael
회원 가입일: 08/17/13
226 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 41
전체 시간: 2,193
