주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Kodak Advantix F350 Front Cover
필요한 것
    1. Disassembling Kodak Advantix F350 Front Cover, Back Cover: 1 단계, 이미지 1개 중 1개
      • Turn off the camera.
      • Locate the power switch on the front of the camera below the camera lens.
      • Slide the switch to the off position.
      댓글 쓰기
    2. Disassembling Kodak Advantix F350 Front Cover: 2 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 2 단계, 이미지 2개 중 2개
      • Locate the 3 screws that hold the back cover to the camera.
      • One screw is located on the film opener side of the camera.
      • The other screws are located on the opposite side of the camera.
      댓글 쓰기
    3. Disassembling Kodak Advantix F350 Front Cover: 3 단계, 이미지 3개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 3 단계, 이미지 3개 중 2개 Disassembling Kodak Advantix F350 Front Cover: 3 단계, 이미지 3개 중 3개
      • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
      댓글 쓰기
    4. Disassembling Kodak Advantix F350 Front Cover: 4 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 4 단계, 이미지 2개 중 2개
      • Open the film door to remove the back cover.
      • Slide the film door lever to the left until the film door opens.
      댓글 쓰기
    5. Disassembling Kodak Advantix F350 Front Cover: 5 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 5 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to pry the case open until a small gap is present.
      • Repeat this process at the top and bottom of the film door to loosen it.
      댓글 쓰기
    6. Disassembling Kodak Advantix F350 Front Cover: 6 단계, 이미지 3개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 6 단계, 이미지 3개 중 2개 Disassembling Kodak Advantix F350 Front Cover: 6 단계, 이미지 3개 중 3개
      • Grab the top and bottom of the case firmly as shown.
      • Gently remove the back of the camera case with a slight twisting motion.
      댓글 쓰기
    1. Disassembling Kodak Advantix F350 Front Cover, Front Cover: 7 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover, Front Cover: 7 단계, 이미지 2개 중 2개
      • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
      • The first 2 are located on the bottom of the camera.
      • The last screw is located behind the flash module.
      • Turn the camera on, and raise the flash module to locate the flash module screw.
      댓글 쓰기
    2. Disassembling Kodak Advantix F350 Front Cover: 8 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 8 단계, 이미지 2개 중 2개
      • Remove the 2 screws at the base of the camera housing.
      • Use the Phillips #00 Precision Screwdriver and remove the screws.
      • Repeat this process for the screw behind the flash module.
      댓글 쓰기
    3. Disassembling Kodak Advantix F350 Front Cover: 9 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 9 단계, 이미지 2개 중 2개
      • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
      댓글 쓰기
    4. Disassembling Kodak Advantix F350 Front Cover: 10 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 10 단계, 이미지 2개 중 2개
      • Remove the flash cover.
      • Remove the flash module by twisting it up and outward of the camera housing.
      • The cover can now be be removed.
      댓글 쓰기
    5. Disassembling Kodak Advantix F350 Front Cover: 11 단계, 이미지 2개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 11 단계, 이미지 2개 중 2개
      • Remove the film door lever.
      • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
      • Using a plastic opening tool, gently pry the switch upwards to remove it.
      댓글 쓰기
    6. Disassembling Kodak Advantix F350 Front Cover: 12 단계, 이미지 1개 중 1개
      • Open the battery door by pushing the lever towards the arrow indicated.
      댓글 쓰기
    7. Disassembling Kodak Advantix F350 Front Cover: 13 단계, 이미지 3개 중 1개 Disassembling Kodak Advantix F350 Front Cover: 13 단계, 이미지 3개 중 2개 Disassembling Kodak Advantix F350 Front Cover: 13 단계, 이미지 3개 중 3개
      • Remove the front cover.
      • Insert your thumb in the film hole and gently pry the bottom loose.
      • Once the front is loose, gently pull it out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
David Cottrell
회원 가입일: 10/04/11
103 평판
안내서 5개를 작성함
UW Stout, Team 1-2, Zhou Fall 2011 UW Stout, Team 1-2, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G2
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 30
전체 시간: 1,358
