주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Konica Compact 8 Front Cover
필요한 것
    1. Disassembling Konica Compact 8 Front Cover, Left side screw: 1 단계, 이미지 1개 중 1개
      • Remove the screw on the left side if the camera is facing your way.
      댓글 쓰기
    2. Disassembling Konica Compact 8 Front Cover, Right side screw: 2 단계, 이미지 1개 중 1개
      • Remove the screw on the right side if the camera is facing you.
      댓글 쓰기
    3. Disassembling Konica Compact 8 Front Cover: 3 단계, 이미지 1개 중 1개
      • Now remove the final screw at the top of the camera. You can now remove the top cover carefully.
      • You can pry the front cover up and down to loosen it. Be careful not to pry horizontally and only vertically. This is because of the open aperture blades that are on the sides.
      댓글 쓰기
    4. Disassembling Konica Compact 8 Front Cover, Finish: 4 단계, 이미지 1개 중 1개
      • The machinery is now open and can be dissasembled further or the front cover might be cleaned freely without worry that cleaning liquid would seep into the camera.
      • Make sure to remember what the "roll and lock" switch was on before dissassembly or to not touch it at all.
      댓글 쓰기
    5. Disassembling Konica Compact 8 Front Cover, Optional: Pushing lever back in place when reassembling: 5 단계, 이미지 1개 중 1개
      • You might need to push the brass lever that holds the wires in place (right under the small board on the leftside) up to fit the front cover back on.
      • If its stuck in place in the wrong position, loosen the screw attached to it a little bit to pry it back in it's original position.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. You might need to push the brass lever that holds the wires in place (right under the small board on the leftside) up to fit the front cover back on. Mine had shifted downwards after taking the cover off and the topcover did not fit back because of it. If its stuck in place in the wrong position, loosen the screw attached to it a little bit to pry it back in it's original position.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
JonasB7
회원 가입일: 11/11/24
485 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 17
전체 시간: 128
