주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Mac Powerbook 140 Keycaps
필요한 것
  1. Disassembling Mac Powerbook 140 Keycaps, Takeing the caps off: 1 단계, 이미지 1개 중 1개
    • The keycaps are connected via 2 clips on the left and the right side of the keycaps. Larger keycaps are connected to stabilizers, be careful when taking these caps off since the underlying plastic has overhangs that can break off.
    • Firstly pry the clip on one side with a spudger. Keep the open clip up while prying the other clip open. Be careful of the stabilizers when taking off larger caps.
    댓글 쓰기
  2. Disassembling Mac Powerbook 140 Keycaps, Take off underlying parts: 2 단계, 이미지 1개 중 1개
    • The board still has the white springs and the silicone cone on it. Grab the white spring with tweezers or by hand and take it off. It has 2 clips on the top and on the bottom.
    • After removing the white part remove the silicone cone with tweezers.
    댓글 쓰기
  3. Disassembling Mac Powerbook 140 Keycaps, Putting the silicone rings back: 3 단계, 이미지 1개 중 1개
    • First put the silicone rings on the circular pillars with a hole. Put the silicone rings with their widest part up.
    댓글 쓰기
    • I found the easiest way to put these back is to put it on rotated to the left then spin it clockwise until it clicks.
    댓글 쓰기
  4. Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: 5 단계, 이미지 2개 중 1개 Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: 5 단계, 이미지 2개 중 2개
    • To correctly orient the keycaps note, that the letters are on the bottom left of the keycaps. Also, the caps are rounder at the bottom. You can find the place for the white spring's arms on the back side of the keycaps.
    댓글 쓰기
결론
To reassemble your device, follow from the 3rd step.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kristóf Kékesi
회원 가입일: 12/16/25
182 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 81
