주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis
필요한 것
  1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: 1 단계, 이미지 3개 중 1개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: 1 단계, 이미지 3개 중 2개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: 1 단계, 이미지 3개 중 3개
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
    댓글 쓰기
  2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: 2 단계, 이미지 3개 중 1개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: 2 단계, 이미지 3개 중 2개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: 2 단계, 이미지 3개 중 3개
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
    댓글 쓰기
  3. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: 3 단계, 이미지 3개 중 1개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: 3 단계, 이미지 3개 중 2개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: 3 단계, 이미지 3개 중 3개
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
    댓글 쓰기
  4. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: 4 단계, 이미지 3개 중 1개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: 4 단계, 이미지 3개 중 2개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: 4 단계, 이미지 3개 중 3개
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
    댓글 쓰기
  5. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: 5 단계, 이미지 3개 중 1개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: 5 단계, 이미지 3개 중 2개 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: 5 단계, 이미지 3개 중 3개
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Taylor Nesheim
회원 가입일: 10/11/11
59 평판
안내서 7개를 작성함
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 회원
CPSU-REGAN-F11S6G9
2 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 47
전체 시간: 2,406
