주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nerf Recon CS-6 Shell
필요한 것
    1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: 1 단계, 이미지 1개 중 1개
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      댓글 쓰기
    2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: 2 단계, 이미지 1개 중 1개
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      댓글 쓰기
    3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: 3 단계, 이미지 2개 중 1개 Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: 3 단계, 이미지 2개 중 2개
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      댓글 쓰기
    4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: 4 단계, 이미지 1개 중 1개
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      댓글 쓰기
    5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: 5 단계, 이미지 1개 중 1개
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      댓글 쓰기
    6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: 6 단계, 이미지 2개 중 1개 Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: 6 단계, 이미지 2개 중 2개
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Asad Qureshi
회원 가입일: 10/22/14
595 평판
안내서 3개를 작성함
Baylor, Team 8-14, Williams Fall 2014 Baylor, Team 8-14, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G14
3 회원들
안내서 6개를 작성함
2가이드 댓글
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - 답글 공유
very useful, thanks!
Sebastian Isaacs - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 45
전체 시간: 12,912
