주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Netatmo Outdoor Camera Main Unit
필요한 것
  1. Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: 1 단계, 이미지 2개 중 1개 Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: 1 단계, 이미지 2개 중 2개
    • Remove the plate at the bottom of the camera by inserting a screwdriver in the slot, and bending while pulling.
    • The panel will lift up and can be removed.
    댓글 쓰기
  2. Disassembling Netatmo Outdoor Camera Main Unit: 2 단계, 이미지 2개 중 1개 Disassembling Netatmo Outdoor Camera Main Unit: 2 단계, 이미지 2개 중 2개
    • Insert a flathead screwdriver into each hole at the front of the camera and push the two tabs to the centre and forwards.
    • It's hard to see, but you need the triangular part at the front, rather than what appears to be a tab at the back.
    • Pushing towards the centre allows the lens cover to come off. These can be done one at a time.
    댓글 쓰기
  3. Disassembling Netatmo Outdoor Camera Main Unit: 3 단계, 이미지 2개 중 1개 Disassembling Netatmo Outdoor Camera Main Unit: 3 단계, 이미지 2개 중 2개
    • Remove the six 2.5mm hex screws using a long Allen key.
    • One screw has an earthing ring wire. Don't forget this when reassembling.
    댓글 쓰기
  4. Disassembling Netatmo Outdoor Camera Main Unit: 4 단계, 이미지 2개 중 1개 Disassembling Netatmo Outdoor Camera Main Unit: 4 단계, 이미지 2개 중 2개
    • Separate the two pieces by pulling slightly on the lower module.
    • Pull the metal housing forward.
    • Pushing the light from the inside can help in removing the shell.
    댓글 쓰기
  5. Disassembling Netatmo Outdoor Camera Main Unit: 5 단계, 이미지 1개 중 1개
    • Using a 1.5mm hex screwdriver remove the four screws holding on the camera module.
    댓글 쓰기
  6. Disassembling Netatmo Outdoor Camera Main Unit: 6 단계, 이미지 2개 중 1개 Disassembling Netatmo Outdoor Camera Main Unit: 6 단계, 이미지 2개 중 2개
    • From this point the housing can be worked up and diagonally to reveal the circuit board, and ribbon cable.
    • Be careful with both the camera module ribbon and the one for the LED lights (which cannot be removed).
    • Do not slide the circuit board within the heatsink otherwise you risk ripping the LED ribbon cable.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
The Virtual Traveller
회원 가입일: 01/14/23
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 86
전체 시간: 1,083
