주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nintendo 64 Cartridge
필요한 것
    1. Disassembling Nintendo 64 Cartridge, Cartridge: 1 단계, 이미지 2개 중 1개 Disassembling Nintendo 64 Cartridge, Cartridge: 1 단계, 이미지 2개 중 2개
      • First flip your game over and you'll see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
      • Take the screws out and peel the case off starting from the top taking care not to force it due to the tabs at the bottom of the cartridge. Outlined in Red
      • The two halves of the case should come apart easily.
      댓글 쓰기
    2. Disassembling Nintendo 64 Cartridge: 2 단계, 이미지 3개 중 1개 Disassembling Nintendo 64 Cartridge: 2 단계, 이미지 3개 중 2개 Disassembling Nintendo 64 Cartridge: 2 단계, 이미지 3개 중 3개
      • On the inside of the front plastic casing the game board and metal shielding are attached with two Phillips head screws. Unscrew them to remove the shielding and access the game board.
      • The top of the metal shielding held on with pressure tabs. Be sure to press down firmly when reassembling.
      • With the shielding off, the main circuit board and pins can be seen.
      댓글 쓰기
    3. Disassembling Nintendo 64 Cartridge: 3 단계, 이미지 3개 중 1개 Disassembling Nintendo 64 Cartridge: 3 단계, 이미지 3개 중 2개 Disassembling Nintendo 64 Cartridge: 3 단계, 이미지 3개 중 3개
      • The only thing holding in the board is the plastic shield on the bottom of the cartridge. No screws are holding it in and is easily removed.
      • Now you can fully take out the cartridge board from the casing.
      • Here you can fully clean the pin set and inspect for damage to the circuit board.
      • NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles
      댓글 쓰기
    4. Disassembling Nintendo 64 Cartridge: 4 단계, 이미지 2개 중 1개 Disassembling Nintendo 64 Cartridge: 4 단계, 이미지 2개 중 2개
      • Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture of isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind).
      • While reassembling the cartridge, remember to put the lower plastic shielding underneath the two pins on the outer casing. There are two like this on both sides.
      댓글 쓰기
결론
To reassemble the cartridge, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 29명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
BWest
회원 가입일: 09/02/10
3,468 평판
안내서 2개를 작성함
OPEN OPEN 회원
Community
88 회원들
안내서 72개를 작성함
1가이드 댓글
Super surprised when I realized the ifixit kit has a gamebit.
Andrew - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 70
지난 30일: 277
전체 시간: 64,465
