주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nokia 2366i Keypad
필요한 것
    1. Disassembling Nokia 2366i Keypad, Battery: 1 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Keypad, Battery: 1 단계, 이미지 2개 중 2개
      • Turn off the phone.
      • Position the phone so that the back side is in view.
      댓글 쓰기
    2. Disassembling Nokia 2366i Keypad: 2 단계, 이미지 1개 중 1개
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      • Remove the back battery cover.
      댓글 쓰기
    3. Disassembling Nokia 2366i Keypad: 3 단계, 이미지 3개 중 1개 Disassembling Nokia 2366i Keypad: 3 단계, 이미지 3개 중 2개 Disassembling Nokia 2366i Keypad: 3 단계, 이미지 3개 중 3개
      • Insert the spudger between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • Carefully lift the battery out of the phone.
      • The battery lifts out of the phone easily.
      댓글 쓰기
    1. Disassembling Nokia 2366i Keypad, Rear Case: 4 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Keypad, Rear Case: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
      댓글 쓰기
    2. Disassembling Nokia 2366i Keypad: 5 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Keypad: 5 단계, 이미지 2개 중 2개
      • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
      • 2 screws at the bottom
      • 2 screws at the top
      댓글 쓰기
    3. Disassembling Nokia 2366i Keypad: 6 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Keypad: 6 단계, 이미지 2개 중 2개
      • Rotate the phone clockwise so the edge is facing you.
      • Insert the spudger in tabs between the outer casing and the inside frame.
      • Slide the spudger upwards.
      • This will remove the rear case of the phone.
      댓글 쓰기
    4. Disassembling Nokia 2366i Keypad: 7 단계, 이미지 1개 중 1개
      • The phone should now be in two different sections.
      • 1) The rear case of the phone.
      • 2) The motherboard and the rest of the phone.
      댓글 쓰기
    1. Disassembling Nokia 2366i Keypad, Motherboard: 8 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Keypad, Motherboard: 8 단계, 이미지 2개 중 2개
      • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
      댓글 쓰기
    2. Disassembling Nokia 2366i Keypad: 9 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Keypad: 9 단계, 이미지 2개 중 2개
      • Rotate the phone counterclockwise so that the edge is facing you.
      • Use the spudger to lift the motherboard out of the base of the phone.
      • Remove the motherboard from the base of the phone.
      댓글 쓰기
    1. Disassembling Nokia 2366i Keypad, Keypad: 10 단계, 이미지 1개 중 1개
      • Place key pad in view.
      댓글 쓰기
    2. Disassembling Nokia 2366i Keypad: 11 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Keypad: 11 단계, 이미지 2개 중 2개
      • Use your fingers to remove the keypad by carefully pulling from the top of the phone towards the bottom of the phone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Michael Machado
회원 가입일: 01/21/11
337 평판
안내서 3개를 작성함
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G14
5 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 1,257
