주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nokia 2366i Motherboard
필요한 것
  1. Disassembling Nokia 2366i Motherboard, Battery: 1 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Motherboard, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off the phone.
    • Position the phone so that the back side is in view.
    댓글 쓰기
  2. Disassembling Nokia 2366i Motherboard: 2 단계, 이미지 1개 중 1개
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    댓글 쓰기
  3. Disassembling Nokia 2366i Motherboard: 3 단계, 이미지 3개 중 1개 Disassembling Nokia 2366i Motherboard: 3 단계, 이미지 3개 중 2개 Disassembling Nokia 2366i Motherboard: 3 단계, 이미지 3개 중 3개
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
    댓글 쓰기
  4. Disassembling Nokia 2366i Motherboard, Rear Case: 4 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Motherboard, Rear Case: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
    댓글 쓰기
  5. Disassembling Nokia 2366i Motherboard: 5 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Motherboard: 5 단계, 이미지 2개 중 2개
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
    댓글 쓰기
  6. Disassembling Nokia 2366i Motherboard: 6 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Motherboard: 6 단계, 이미지 2개 중 2개
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
    댓글 쓰기
  7. Disassembling Nokia 2366i Motherboard: 7 단계, 이미지 1개 중 1개
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
    댓글 쓰기
  8. Disassembling Nokia 2366i Motherboard, Motherboard: 8 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Motherboard, Motherboard: 8 단계, 이미지 2개 중 2개
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
    댓글 쓰기
  9. Disassembling Nokia 2366i Motherboard: 9 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Motherboard: 9 단계, 이미지 2개 중 2개
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonathan Newman
회원 가입일: 01/21/11
516 평판
안내서 4개를 작성함
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G14
5 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 39
전체 시간: 1,934
