주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nokia E61i Volume Control Buttons
필요한 것
    1. Disassembling Nokia E61i Volume Control Buttons, Battery: 1 단계, 이미지 2개 중 1개 Disassembling Nokia E61i Volume Control Buttons, Battery: 1 단계, 이미지 2개 중 2개
      • First, gather all necessary tools.
      • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
      • Slide the back cover downwards off of the phone while pressing down on the tab.
      댓글 쓰기
    2. Disassembling Nokia E61i Volume Control Buttons: 2 단계, 이미지 1개 중 1개
      • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
      댓글 쓰기
    3. Disassembling Nokia E61i Volume Control Buttons: 3 단계, 이미지 1개 중 1개
      • Lift the battery out using your finger.
      • The E61i uses a Nokia BP-4L standard battery.
      댓글 쓰기
    1. Disassembling Nokia E61i Volume Control Buttons, Front Cover: 4 단계, 이미지 2개 중 1개 Disassembling Nokia E61i Volume Control Buttons, Front Cover: 4 단계, 이미지 2개 중 2개
      • To remove the top of the back cover, pry the sides and pop it off.
      • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
      댓글 쓰기
    2. Disassembling Nokia E61i Volume Control Buttons: 5 단계, 이미지 1개 중 1개
      • Remove the cover by pulling it up and off.
      댓글 쓰기
    1. Disassembling Nokia E61i Volume Control Buttons, Display: 6 단계, 이미지 2개 중 1개 Disassembling Nokia E61i Volume Control Buttons, Display: 6 단계, 이미지 2개 중 2개
      • Take off the casing and keyboard.
      • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
      • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
      • Lift the ribbon, disconnecting contact with the motherboard.
      • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
      댓글 쓰기
    2. Disassembling Nokia E61i Volume Control Buttons: 7 단계, 이미지 2개 중 1개 Disassembling Nokia E61i Volume Control Buttons: 7 단계, 이미지 2개 중 2개
      • Gently pull the screen off of the phone.
      • Be sure not to rip the sticker that connects the display and the motherboard.
      • Pull the silver case off to completely free the cracked or damaged screen.
      댓글 쓰기
    1. Disassembling Nokia E61i Volume Control Buttons, Motherboard: 8 단계, 이미지 3개 중 1개 Disassembling Nokia E61i Volume Control Buttons, Motherboard: 8 단계, 이미지 3개 중 2개 Disassembling Nokia E61i Volume Control Buttons, Motherboard: 8 단계, 이미지 3개 중 3개
      • Pull the green motherboard from the back casing.
      댓글 쓰기
    1. Disassembling Nokia E61i Volume Control Buttons, Volume Control Buttons: 9 단계, 이미지 1개 중 1개
      • The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
      댓글 쓰기
    2. Disassembling Nokia E61i Volume Control Buttons: 10 단계, 이미지 1개 중 1개
      • Next, remove the volume control buttons from the cover by pushing or pulling them out away from the interior of the cover.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Christopher Patton
회원 가입일: 04/07/11
208 평판
안내서 12개를 작성함
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G63
5 회원들
안내서 84개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 29
전체 시간: 2,022
