주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Planet Eclipse Etha Frame
필요한 것
  1. Disassembling Planet Eclipse Etha Frame, Regulator: 1 단계, 이미지 2개 중 1개 Disassembling Planet Eclipse Etha Frame, Regulator: 1 단계, 이미지 2개 중 2개
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
    댓글 쓰기
  2. Disassembling Planet Eclipse Etha Frame: 2 단계, 이미지 2개 중 1개 Disassembling Planet Eclipse Etha Frame: 2 단계, 이미지 2개 중 2개
    • Remove the regulator by unscrewing it in a clockwise direction.
    댓글 쓰기
  3. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: 3 단계, 이미지 2개 중 1개 Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: 3 단계, 이미지 2개 중 2개
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
    댓글 쓰기
  4. Disassembling Planet Eclipse Etha Frame: 4 단계, 이미지 1개 중 1개
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
    댓글 쓰기
  5. Disassembling Planet Eclipse Etha Frame: 5 단계, 이미지 2개 중 1개 Disassembling Planet Eclipse Etha Frame: 5 단계, 이미지 2개 중 2개
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
    댓글 쓰기
  6. Disassembling Planet Eclipse Etha Frame, Frame: 6 단계, 이미지 2개 중 1개 Disassembling Planet Eclipse Etha Frame, Frame: 6 단계, 이미지 2개 중 2개
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
    댓글 쓰기
  7. Disassembling Planet Eclipse Etha Frame: 7 단계, 이미지 2개 중 1개 Disassembling Planet Eclipse Etha Frame: 7 단계, 이미지 2개 중 2개
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
    댓글 쓰기
  8. Disassembling Planet Eclipse Etha Frame: 8 단계, 이미지 1개 중 1개
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
nicholasj6
회원 가입일: 10/14/14
261 평판
안내서 2개를 작성함
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G42
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 654
