주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling REL T5 Transformer
필요한 것
  1. Disassembling REL T5 Transformer, Remove screws: 1 단계, 이미지 3개 중 1개 Disassembling REL T5 Transformer, Remove screws: 1 단계, 이미지 3개 중 2개 Disassembling REL T5 Transformer, Remove screws: 1 단계, 이미지 3개 중 3개
    • Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
    • Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
    • Make sure to support the plate amp by gripping the heat sink.
    • Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
    • Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
    댓글 쓰기
  2. Disassembling REL T5 Transformer, Disconnect the driver: 2 단계, 이미지 2개 중 1개 Disassembling REL T5 Transformer, Disconnect the driver: 2 단계, 이미지 2개 중 2개
    • The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
    댓글 쓰기
  3. Disassembling REL T5 Transformer, Remove plate amp: 3 단계, 이미지 1개 중 1개
    • You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
    • Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
    댓글 쓰기
  4. Disassembling REL T5 Transformer, Snip all connecting trywraps: 4 단계, 이미지 2개 중 1개 Disassembling REL T5 Transformer, Snip all connecting trywraps: 4 단계, 이미지 2개 중 2개
    • Snip all tywraps, such that all cables can be manipulated freely.
    댓글 쓰기
  5. Disassembling REL T5 Transformer, Disconnect connectors: 5 단계, 이미지 2개 중 1개 Disassembling REL T5 Transformer, Disconnect connectors: 5 단계, 이미지 2개 중 2개
    • Disconnect all connectors that tie to the transformer
    • Make sure that all leads can be manipulated freely.
    댓글 쓰기
  6. Disassembling REL T5 Transformer, Loosen screws: 6 단계, 이미지 2개 중 1개 Disassembling REL T5 Transformer, Loosen screws: 6 단계, 이미지 2개 중 2개
    • Start loosening the screws on the back using the m3 hex tool
    • Don't remove them fully, yet though.
    댓글 쓰기
  7. Disassembling REL T5 Transformer, Remove screws: 7 단계, 이미지 2개 중 1개 Disassembling REL T5 Transformer, Remove screws: 7 단계, 이미지 2개 중 2개
    • Turn the amp on it's back.
    • Remove the nuts from the screws that where loosened on the back.
    • Remove the philips screws using a #2.
    댓글 쓰기
  8. Disassembling REL T5 Transformer, Loosen dampening rubber: 8 단계, 이미지 1개 중 1개
    • Loosen the dampening rubber by running a Halberd Spudger underneath it.
    • The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
    댓글 쓰기
  9. Disassembling REL T5 Transformer, Remove transformer: 9 단계, 이미지 2개 중 1개 Disassembling REL T5 Transformer, Remove transformer: 9 단계, 이미지 2개 중 2개
    • You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jasper van Zuijlen
회원 가입일: 04/21/25
1,044 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 17
