주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Siemens A56 Motherboard from Keypad Interface
필요한 것
    1. Disassembling Siemens A56 Motherboard from Keypad Interface, Battery: 1 단계, 이미지 1개 중 1개
      • Press down on the grooved area firmly in the direction of arrow #1.
      • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
      • Photos taken from: http://theinformr.com/uploads/manuals/si...
      댓글 쓰기
    2. Disassembling Siemens A56 Motherboard from Keypad Interface: 2 단계, 이미지 1개 중 1개
      • Turn off the phone before removing the battery to avoid damage.
      • Press the latch on the battery in the direction of arrow #3.
      • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
      • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
      댓글 쓰기
    1. Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: 3 단계, 이미지 3개 중 1개 Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: 3 단계, 이미지 3개 중 2개 Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: 3 단계, 이미지 3개 중 3개
      • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
      • Pull up on the two plastic clips at the top of the phone.
      • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
      댓글 쓰기
    1. Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: 4 단계, 이미지 3개 중 1개 Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: 4 단계, 이미지 3개 중 2개 Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: 4 단계, 이미지 3개 중 3개
      • Along the side of the metal frame of the phone, locate the six screws.
      • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
      • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
      댓글 쓰기
    2. Disassembling Siemens A56 Motherboard from Keypad Interface: 5 단계, 이미지 3개 중 1개 Disassembling Siemens A56 Motherboard from Keypad Interface: 5 단계, 이미지 3개 중 2개 Disassembling Siemens A56 Motherboard from Keypad Interface: 5 단계, 이미지 3개 중 3개
      • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
      • Gently remove the motherboard from the back plastic cover.
      • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
      댓글 쓰기
    1. Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: 6 단계, 이미지 3개 중 1개 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: 6 단계, 이미지 3개 중 2개 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: 6 단계, 이미지 3개 중 3개
      • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
      • Once loosened, the metal frame should be able to be lifted from the motherboard.
      댓글 쓰기
    1. Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: 7 단계, 이미지 3개 중 1개 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: 7 단계, 이미지 3개 중 2개 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: 7 단계, 이미지 3개 중 3개
      • Insert the fine-tipped spudger in between the motherboard and the keypad interface.
      • Gently work the spudger across the length of the motherboard.
      • An adhesive exists between the motherboard and the keypad interface.
      • Once loosened, the motherboard should easily separate from the keypad interface.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Joseph Casey
회원 가입일: 03/26/14
414 평판
안내서 4개를 작성함
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 회원
CLEM-BENSON-S14S6G6
4 회원들
안내서 63개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 27
전체 시간: 572
