주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Sirius Stiletto 100 Internal Antenna
필요한 것
    1. Disassembling Sirius Stiletto 100 Internal Antenna, Front Cover: 1 단계, 이미지 2개 중 1개 Disassembling Sirius Stiletto 100 Internal Antenna, Front Cover: 1 단계, 이미지 2개 중 2개
      • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
      댓글 쓰기
    2. Disassembling Sirius Stiletto 100 Internal Antenna: 2 단계, 이미지 2개 중 1개 Disassembling Sirius Stiletto 100 Internal Antenna: 2 단계, 이미지 2개 중 2개
      • Use a Philip's head screw driver to remove the screws from the case.
      • Place the screws in a small container to avoid losing them.
      댓글 쓰기
    3. Disassembling Sirius Stiletto 100 Internal Antenna: 3 단계, 이미지 3개 중 1개 Disassembling Sirius Stiletto 100 Internal Antenna: 3 단계, 이미지 3개 중 2개 Disassembling Sirius Stiletto 100 Internal Antenna: 3 단계, 이미지 3개 중 3개
      • Remove the front cover.
      • First, insert a small pry bar where the black front cover and white back cover meet.
      • Begin prying the black plastic up, slowing moving around to the bottom and other side.
      • At an angle, carefully pull up on the front cover separate the two pieces.
      • Excellent! Now you have removed the front cover!
      댓글 쓰기
    1. Disassembling Sirius Stiletto 100 Internal Antenna, Circuit Board: 4 단계, 이미지 1개 중 1개
      • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
      댓글 쓰기
    2. Disassembling Sirius Stiletto 100 Internal Antenna: 5 단계, 이미지 2개 중 1개 Disassembling Sirius Stiletto 100 Internal Antenna: 5 단계, 이미지 2개 중 2개
      • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
      댓글 쓰기
    3. Disassembling Sirius Stiletto 100 Internal Antenna: 6 단계, 이미지 1개 중 1개
      • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
      댓글 쓰기
    1. Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: 7 단계, 이미지 3개 중 1개 Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: 7 단계, 이미지 3개 중 2개 Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: 7 단계, 이미지 3개 중 3개
      • Flip the circuit board over to look at the back side, so that LCD screen is facing away from you.
      • Use a Phillip's head screwdriver to remove the screw from the back of the internal antenna.
      댓글 쓰기
    2. Disassembling Sirius Stiletto 100 Internal Antenna: 8 단계, 이미지 2개 중 1개 Disassembling Sirius Stiletto 100 Internal Antenna: 8 단계, 이미지 2개 중 2개
      • Use your fingers to pry the internal antenna off of the circuit board. You may need to wiggle it back and forth to successfully remove it.
      • Woohoo! You have removed the internal antenna!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Trey
회원 가입일: 03/09/12
86 평판
안내서 2개를 작성함
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012 회원
CLEM-BENSON-S12S2G1
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 3,158
