주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Sony Reader Touch Edition PRS-600 Inner Casing
필요한 것
    1. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Back Panel: 1 단계, 이미지 1개 중 1개
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      댓글 쓰기
    2. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: 2 단계, 이미지 1개 중 1개
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      댓글 쓰기
    3. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: 3 단계, 이미지 1개 중 1개
      • This is what the device should look like once the back cover panel has been removed.
      댓글 쓰기
    1. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Battery: 4 단계, 이미지 1개 중 1개
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      댓글 쓰기
    2. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: 5 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      댓글 쓰기
    1. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Inner Casing: 6 단계, 이미지 1개 중 1개
      • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
      댓글 쓰기
    2. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: 7 단계, 이미지 1개 중 1개
      • Pry open the black casing to access the screw that is holding down the battery holder.
      • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
      • Lift the black inner casing and the battery holder out of the device.
      • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Terrika Ngobili
회원 가입일: 10/13/14
873 평판
안내서 7개를 작성함
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 회원
CLEM-BENSON-F14S1G4
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 1,240
