주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Translucent Rubber Flashlight Battery Power Component
    1. Disassembling Translucent Rubber Flashlight Battery Power Component, Disassembling Translucent Rubber Flashlight Battery Power Component: 1 단계, 이미지 1개 중 1개
      • Remove light mechanism from body containing battery. Twist light bulb (red circle) counterclockwise while holding base of flashlight (black circle).
      댓글 쓰기
    2. Disassembling Translucent Rubber Flashlight Battery Power Component: 2 단계, 이미지 1개 중 1개
      • Angle body of flashlight until two AA batteries fall out. Store battery components.
      댓글 쓰기
    3. Disassembling Translucent Rubber Flashlight Battery Power Component: 3 단계, 이미지 1개 중 1개
      • Pull off rubber chassis of flashlight. Peel back rubber on battery side of flashlight first (red circle). Grip remaining rubber (black circle) and pull off plastic/metal body in direction counter to opening.
      댓글 쓰기
    4. Disassembling Translucent Rubber Flashlight Battery Power Component: 4 단계, 이미지 1개 중 1개
      • Remove metal apparatus containing button switch first by bending piece in arc shape. Carefully pull out clipped tip as shown.
      댓글 쓰기
    5. Disassembling Translucent Rubber Flashlight Battery Power Component: 5 단계, 이미지 2개 중 1개 Disassembling Translucent Rubber Flashlight Battery Power Component: 5 단계, 이미지 2개 중 2개
      • Using the freed tip, detach the bottom of the metal switch connected to the spring of the grounded/negative end where the AA batteries are located (circle).
      • Push metal end into square hole so clip detaches from battery spring (circle). Pull out rest of clip avoiding spring, so metal switch freed from body.
      댓글 쓰기
    6. Disassembling Translucent Rubber Flashlight Battery Power Component: 6 단계, 이미지 2개 중 1개 Disassembling Translucent Rubber Flashlight Battery Power Component: 6 단계, 이미지 2개 중 2개
      • Spring connected to flashlight base removed using tip of metal switch (circle) hooking and pulling into opening.
      • Initiate battery switch disassembly (circle).
      댓글 쓰기
    7. Disassembling Translucent Rubber Flashlight Battery Power Component: 7 단계, 이미지 3개 중 1개 Disassembling Translucent Rubber Flashlight Battery Power Component: 7 단계, 이미지 3개 중 2개 Disassembling Translucent Rubber Flashlight Battery Power Component: 7 단계, 이미지 3개 중 3개
      • The switch mechanism disassembly removes the button attached to the lid (red circle) from the grooves (blue circle) containing the switch components.
      • Next, remove the spring first and then metallic, grooved pressure plate which contained the spring (red circle) using hand.
      • Finally, remove metal connections of battery switch by lifting holes (red circle) off containment piece.
      댓글 쓰기
    8. Disassembling Translucent Rubber Flashlight Battery Power Component: 8 단계, 이미지 1개 중 1개
      • The battery components of translucent flashlight completely disassembled.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Phillip Phung
회원 가입일: 01/19/12
666 평판
안내서 9개를 작성함
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 회원
CPSU-MANESS-W12S8G18
4 회원들
안내서 12개를 작성함
1가이드 댓글
thanks a lot that really help. especially the on off switch 2 spring part. mine was a rear switch though
John Doe - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 73
전체 시간: 3,459
