주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling VTech MobiGo Touch Learning System Keyboard
필요한 것
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: 1 단계, 이미지 1개 중 1개
      • Remove the battery covers and the four batteries.
      댓글 쓰기
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: 2 단계, 이미지 2개 중 1개 Disassembling VTech MobiGo Touch Learning System Keyboard: 2 단계, 이미지 2개 중 2개
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      댓글 쓰기
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: 3 단계, 이미지 2개 중 1개 Disassembling VTech MobiGo Touch Learning System Keyboard: 3 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      댓글 쓰기
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: 4 단계, 이미지 2개 중 1개 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: 4 단계, 이미지 2개 중 2개
      • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
      • Use light pressure to prevent damage to the circuit board.
      댓글 쓰기
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: 5 단계, 이미지 1개 중 1개
      • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
      • Once the screw is removed, remove the blue plastic cover.
      댓글 쓰기
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: 6 단계, 이미지 2개 중 1개 Disassembling VTech MobiGo Touch Learning System Keyboard: 6 단계, 이미지 2개 중 2개
      • Remove the two 4.0 mm Philips J0 screws located on the orange case.
      • Use gentle force to prevent stripping of screws.
      댓글 쓰기
    4. Disassembling VTech MobiGo Touch Learning System Keyboard: 7 단계, 이미지 3개 중 1개 Disassembling VTech MobiGo Touch Learning System Keyboard: 7 단계, 이미지 3개 중 2개 Disassembling VTech MobiGo Touch Learning System Keyboard: 7 단계, 이미지 3개 중 3개
      • Remove the two "L" shaped brackets located on both sides of the device.
      • Use the magnetic mat to store these brackets.
      댓글 쓰기
    5. Disassembling VTech MobiGo Touch Learning System Keyboard: 8 단계, 이미지 1개 중 1개
      • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
      댓글 쓰기
    6. Disassembling VTech MobiGo Touch Learning System Keyboard: 9 단계, 이미지 2개 중 1개 Disassembling VTech MobiGo Touch Learning System Keyboard: 9 단계, 이미지 2개 중 2개
      • Gently lift the circuit board from the case using a plastic opening tool.
      • Make sure to use a plastic opening tool for this step.
      댓글 쓰기
    7. Disassembling VTech MobiGo Touch Learning System Keyboard: 10 단계, 이미지 1개 중 1개
      • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
      • Keep the circuit board out of the way to avoid damaging it.
      댓글 쓰기
    8. Disassembling VTech MobiGo Touch Learning System Keyboard: 11 단계, 이미지 1개 중 1개
      • Slowly remove the keyboard panel.
      • Use a spudger if necessary.
      • The keys will fall out once the keyboard panel is removed.
      • Remove all of the keys and set them aside with the keyboard panel.
      댓글 쓰기
    9. Disassembling VTech MobiGo Touch Learning System Keyboard: 12 단계, 이미지 1개 중 1개
      • Gently remove the keyboard circuit board with a plastic opening tool.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
RBansil
회원 가입일: 08/27/15
221 평판
안내서 2개를 작성함
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G3
3 회원들
안내서 49개를 작성함
1가이드 댓글
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 34
전체 시간: 2,468
