주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Wii Balance Board
필요한 것
  1. Disassembling Wii Balance Board, Floor Unit: 1 단계, 이미지 1개 중 1개
    • Unscrew these #1 Philips screws, and leave them in the plastic foot holders.
    댓글 쓰기
  2. Disassembling Wii Balance Board: 2 단계, 이미지 1개 중 1개
    • Remove the foot holders and place them on the side
    댓글 쓰기
  3. Disassembling Wii Balance Board: 3 단계, 이미지 1개 중 1개
    • Remove the four feet and place them on the side
    댓글 쓰기
  4. Disassembling Wii Balance Board: 4 단계, 이미지 1개 중 1개
    • Remove these #1 Philips screws, and leave them in their counterbores
    댓글 쓰기
  5. Disassembling Wii Balance Board: 5 단계, 이미지 1개 중 1개
    • Lift grey shell off and place to the side to reveal:
    • ADC and Logic board
    • Bluetooth module
    • Strain gauges
    • Battery holder
    댓글 쓰기
  6. Disassembling Wii Balance Board: 6 단계, 이미지 1개 중 1개
    • The ADC and Logic board contains:
    • Bluetooth module
    • Power button connector
    • Battery and sync button connector
    • Strain gauge wheatstone bridge connections
    • The topmost connection for each of the four bridge connections is the ground; relative to this, the two middle connections should be at 1.2 VDC, and the bottom should be at 2.7 VDC
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
Pete Marchetto
회원 가입일: 01/25/11
667 평판
안내서 2개를 작성함
5가이드 댓글
Great stuff Pete, being able to fix the wifi board got me mucho street cred with " her indoors " and lots of other goodies that go along with that
HENRY - 답글 공유
Can I take out the battery box without removing the bottom?
Richard Merchant - 답글 공유
No, you can't. You will have to follow this procedure completely.
paulo lima - 답글 공유
Thank you! I was able to fix our 10 year old balance board.
the kids think I’m a roakstar, for now anyway.
lisadubya - 답글 공유
is there schematics for the power pcb
Josué Hernandez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 20
지난 30일: 92
전체 시간: 13,803
