주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling the Circuit Board
필요한 것
    1. Disassembling the Circuit Board, Cracking the Case: 1 단계, 이미지 1개 중 1개
      • Turn the device upside down so that the three rubber pads are facing up.
      댓글 쓰기
    2. Disassembling the Circuit Board: 2 단계, 이미지 1개 중 1개
      • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
      댓글 쓰기
    3. Disassembling the Circuit Board: 3 단계, 이미지 1개 중 1개
      • Remove the heated rubber pad with a plastic opening tool.
      • Repeat steps 2 and 3 for the two remaining rubber pads.
      댓글 쓰기
    4. Disassembling the Circuit Board: 4 단계, 이미지 2개 중 1개 Disassembling the Circuit Board: 4 단계, 이미지 2개 중 2개
      • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
      댓글 쓰기
    5. Disassembling the Circuit Board: 5 단계, 이미지 3개 중 1개 Disassembling the Circuit Board: 5 단계, 이미지 3개 중 2개 Disassembling the Circuit Board: 5 단계, 이미지 3개 중 3개
      • Open the device along its seam.
      • Be careful when separating the device because there are wires connecting the two seperate halves.
      댓글 쓰기
    6. Disassembling the Circuit Board: 6 단계, 이미지 1개 중 1개
      • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
      댓글 쓰기
    7. Disassembling the Circuit Board: 7 단계, 이미지 2개 중 1개 Disassembling the Circuit Board: 7 단계, 이미지 2개 중 2개
      • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
      댓글 쓰기
    1. Disassembling the Circuit Board, Circuit Board: 8 단계, 이미지 2개 중 1개 Disassembling the Circuit Board, Circuit Board: 8 단계, 이미지 2개 중 2개
      • Remove the three 1 cm T-10 Torx screws.
      댓글 쓰기
    2. Disassembling the Circuit Board: 9 단계, 이미지 1개 중 1개
      • Carefully press out the white base tube and push up on the circuit board.
      • Note that there is a small wire connecting the circuit board to the base.
      댓글 쓰기
    3. Disassembling the Circuit Board: 10 단계, 이미지 2개 중 1개 Disassembling the Circuit Board: 10 단계, 이미지 2개 중 2개
      • Pull the white wire out of the hot glue.
      댓글 쓰기
    4. Disassembling the Circuit Board: 11 단계, 이미지 3개 중 1개 Disassembling the Circuit Board: 11 단계, 이미지 3개 중 2개 Disassembling the Circuit Board: 11 단계, 이미지 3개 중 3개
      • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
      • Remove the heat sink; it should detach from the bottom of the device.
      댓글 쓰기
    5. Disassembling the Circuit Board: 12 단계, 이미지 3개 중 1개 Disassembling the Circuit Board: 12 단계, 이미지 3개 중 2개 Disassembling the Circuit Board: 12 단계, 이미지 3개 중 3개
      • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
      • Turn the device so that the base tube is on top.
      • Remove the base tube by pulling up.
      • May need to cut the rubber adhesive between the base tube to the circuit board.
      댓글 쓰기
결론
To reassemble your device, follow these steps in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Janessa D Cabrera
회원 가입일: 01/23/14
547 평판
안내서 4개를 작성함
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014 회원
CPSU-MANESS-W14S9G28
4 회원들
안내서 31개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 47
전체 시간: 5,414
