주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Diswoe Switch-01 Battery Replacement
필요한 것
  1. Diswoe Switch-01 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Diswoe Switch-01 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Diswoe Switch-01 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
    • Remove the handgrips from the controller.
    댓글 쓰기
  2. Diswoe Switch-01 Battery Replacement: 2 단계, 이미지 3개 중 1개 Diswoe Switch-01 Battery Replacement: 2 단계, 이미지 3개 중 2개 Diswoe Switch-01 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the controller over so the bottom is facing up.
    • Use a Phillips screwdriver to remove the five screws from the back case.
    댓글 쓰기
  3. Diswoe Switch-01 Battery Replacement: 3 단계, 이미지 3개 중 1개 Diswoe Switch-01 Battery Replacement: 3 단계, 이미지 3개 중 2개 Diswoe Switch-01 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Use both hands to carefully remove the back cover.
    • For help removing the back cover, use a spudger to pry along the seam between the top and bottom case.
    • Don't pull the back cover off quickly or forcefully as the wires that are connected are easy to break.
    댓글 쓰기
  4. Diswoe Switch-01 Battery Replacement: 4 단계, 이미지 3개 중 1개 Diswoe Switch-01 Battery Replacement: 4 단계, 이미지 3개 중 2개 Diswoe Switch-01 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated
    댓글 쓰기
  5. Diswoe Switch-01 Battery Replacement: 5 단계, 이미지 2개 중 1개 Diswoe Switch-01 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the battery from the main circuit board.
    • The battery is held in place by sticky foam. If you aren't able to remove it easily by hand, use a spudger to gently loosen the adhesive and then remove the battery.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jonathan Bautista
회원 가입일: 09/25/24
251 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-3, Kershman Fall 2024 CSU Los Angeles, Team 2-3, Kershman Fall 2024 회원
CSULA-KERSHMAN-F24S2G3
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 43
전체 시간: 520
