주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dopo Double Power 7 Battery Replacement
필요한 것
    1. Dopo Double Power 7 Battery Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • The rear panel is secured to the front case and can simply be pried apart without damage.
      댓글 쓰기
    2. Dopo Double Power 7 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
      댓글 쓰기
    3. Dopo Double Power 7 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
      댓글 쓰기
    4. Dopo Double Power 7 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • The rear panel should come completely off.
      댓글 쓰기
    1. Dopo Double Power 7 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • Cut only the red and black wires attaching the battery to the motherboard.
      • Be sure to remove any remaining wire attached to the motherboard.
      댓글 쓰기
    2. Dopo Double Power 7 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Using a metal spudger, carefully pry the battery away from the digitizer.
      • Be careful to not damage the battery. This could result in injury.
      댓글 쓰기
    3. Dopo Double Power 7 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
      • Twist the strands of the spliced wire together.
      • Using a soldering iron, apply heat to one bare wire connections you have just made.
      • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
      • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
      • Repeat this process with the other wire.
      • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
      • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
mike pelosi
회원 가입일: 10/30/15
682 평판
안내서 6개를 작성함
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 회원
UMASSD-MILES-F15S1G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 25
전체 시간: 1,345
