주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dopo Double Power 7 Digitizer Replacement
필요한 것
    1. Dopo Double Power 7 Digitizer Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • The rear panel is secured to the front case and can simply be pried apart without damage.
      댓글 쓰기
    2. Dopo Double Power 7 Digitizer Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
      댓글 쓰기
    3. Dopo Double Power 7 Digitizer Replacement: 3 단계, 이미지 1개 중 1개
      • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
      댓글 쓰기
    4. Dopo Double Power 7 Digitizer Replacement: 4 단계, 이미지 1개 중 1개
      • The rear panel should come completely off.
      댓글 쓰기
    1. Dopo Double Power 7 Digitizer Replacement, Camera: 5 단계, 이미지 1개 중 1개
      • Remove any black static tape that may be covering the motherboard.
      댓글 쓰기
    2. Dopo Double Power 7 Digitizer Replacement: 6 단계, 이미지 2개 중 1개 Dopo Double Power 7 Digitizer Replacement: 6 단계, 이미지 2개 중 2개
      • The camera is taped in place.
      • Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
      • Our cable had previously been cut but yours can be disconnected by lifting up on the black section of the socket, as shown by the arrow, and pulling the cable out.
      • Simply, pull back the tape and remove the camera.
      댓글 쓰기
    1. Dopo Double Power 7 Digitizer Replacement, Digitizer: 7 단계, 이미지 2개 중 1개 Dopo Double Power 7 Digitizer Replacement, Digitizer: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a Phillips Head Screwdriver size 0.
      • Remove the four screws holding the motherboard inplace.
      • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
      • The cables can be disconnected by lifting up on the black section of the socket.
      • Once the lever is lifted, pull out the cable by gently tugging on it.
      댓글 쓰기
    2. Dopo Double Power 7 Digitizer Replacement: 8 단계, 이미지 1개 중 1개
      • Using wire cutters, cut only the gray wire.
      댓글 쓰기
    3. Dopo Double Power 7 Digitizer Replacement: 9 단계, 이미지 1개 중 1개
      • Using a metal spudger, carefully pry the battery away from the digitizer.
      • Be careful not to damage the battery.
      • At this point, the battery and the motherboard will still be connected although it is not shown in the image.
      댓글 쓰기
    4. Dopo Double Power 7 Digitizer Replacement: 10 단계, 이미지 1개 중 1개
      • The back of the digitizer is attached along the edge by 12 plastic clips.
      댓글 쓰기
    5. Dopo Double Power 7 Digitizer Replacement: 11 단계, 이미지 1개 중 1개
      • The best way to remove the digitizer is to use a plastic tool and pull back the clips so that it can lift out.
      • Be gentle and be sure not to break any of the clips.
      댓글 쓰기
    6. Dopo Double Power 7 Digitizer Replacement: 12 단계, 이미지 2개 중 1개 Dopo Double Power 7 Digitizer Replacement: 12 단계, 이미지 2개 중 2개
      • The digitizer can now be removed and replaced.
      댓글 쓰기
    7. Dopo Double Power 7 Digitizer Replacement: 13 단계, 이미지 2개 중 1개 Dopo Double Power 7 Digitizer Replacement: 13 단계, 이미지 2개 중 2개
      • Soldering will be required to connect the new digitizer.
      • Any remaining wire left from the old digitizer will need to be removed from the motherboard.
      • Take care not to burn yourself or damage the motherboard, wires, or new digitizer while soldering.
      • Solder the new digitizer to the soldering point shown within the image.
      • Using wire strippers, strip the end of the gray wire connected to the new digitizer about a 1/8".
      • Solder the gray wire to the soldering point on the motherboard as shown within the image.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
mike pelosi
회원 가입일: 10/30/15
682 평판
안내서 6개를 작성함
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 회원
UMASSD-MILES-F15S1G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 24
전체 시간: 904
