주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Draft Inducer Motor Replacement
필요한 것
    1. Draft Inducer Motor Replacement, Draft Inducer Motor: 1 단계, 이미지 2개 중 1개 Draft Inducer Motor Replacement, Draft Inducer Motor: 1 단계, 이미지 2개 중 2개
      • Start by turning off the flow of gas to your furnace, as well as cutting power to the whole furnace by flipping the service switch to the "Off" position.
      • If your furnace doesn't have a service switch nearby, you'll need to cut power to it at the breaker box.
      댓글 쓰기
    2. Draft Inducer Motor Replacement: 2 단계, 이미지 2개 중 1개 Draft Inducer Motor Replacement: 2 단계, 이미지 2개 중 2개
      • Grab the handle on the front panel marked "Lift" and push up to release the panel. Place it off to the side.
      댓글 쓰기
    3. Draft Inducer Motor Replacement: 3 단계, 이미지 3개 중 1개 Draft Inducer Motor Replacement: 3 단계, 이미지 3개 중 2개 Draft Inducer Motor Replacement: 3 단계, 이미지 3개 중 3개
      • The draft inducer is located in the upper-left area of the furnace chamber.
      • Unplug the motor's Molex connector.
      • Your specific furnace model may use a draft inducer with two small connectors on the motor itself, rather than a single Molex connector.
      댓글 쓰기
    4. Draft Inducer Motor Replacement: 4 단계, 이미지 2개 중 1개 Draft Inducer Motor Replacement: 4 단계, 이미지 2개 중 2개
      • Use a flathead screwdriver or a 1/4-inch socket to remove the two screws holding the shield plate to the draft inducer assembly.
      • Remove the plate and set it off to the side.
      • Be sure to keep track of all the screws and bolts!
      댓글 쓰기
    5. Draft Inducer Motor Replacement: 5 단계, 이미지 3개 중 1개 Draft Inducer Motor Replacement: 5 단계, 이미지 3개 중 2개 Draft Inducer Motor Replacement: 5 단계, 이미지 3개 중 3개
      • Use a 1/4-inch socket to remove the three mounting bolts securing the draft inducer assembly to the furnace.
      • Support the motor and assembly from the bottom and slowly remove it from the furnace.
      댓글 쓰기
    6. Draft Inducer Motor Replacement: 6 단계, 이미지 2개 중 1개 Draft Inducer Motor Replacement: 6 단계, 이미지 2개 중 2개
      • Use a flathead screwdriver or a small pry tool to carefully pry off the circular clip from the cooling fan.
      • Be careful not to apply a lot of pressure on the fan itself, since it's made of plastic and will break with enough force.
      댓글 쓰기
    7. Draft Inducer Motor Replacement: 7 단계, 이미지 3개 중 1개 Draft Inducer Motor Replacement: 7 단계, 이미지 3개 중 2개 Draft Inducer Motor Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the cooling fan from the motor's driveshaft.
      • You may need to apply a decent amount of pressure and wiggle the fan in order to knock it loose.
      댓글 쓰기
    8. Draft Inducer Motor Replacement: 8 단계, 이미지 3개 중 1개 Draft Inducer Motor Replacement: 8 단계, 이미지 3개 중 2개 Draft Inducer Motor Replacement: 8 단계, 이미지 3개 중 3개
      • Flip the assembly over and use a 1/8-inch hex key to loosen the set screw securing the blower fan to the motor's driveshaft.
      • More than likely, the fan and set screw will be rusted and seized to the driveshaft. A few sprays of penetrating oil will help loosen it up.
      댓글 쓰기
    9. Draft Inducer Motor Replacement: 9 단계, 이미지 3개 중 1개 Draft Inducer Motor Replacement: 9 단계, 이미지 3개 중 2개 Draft Inducer Motor Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the blower fan from the motor's driveshaft.
      • As with the cooling fan, you may need to apply a decent amount of pressure and wiggle the blower fan in order to remove it.
      댓글 쓰기
    10. Draft Inducer Motor Replacement: 10 단계, 이미지 3개 중 1개 Draft Inducer Motor Replacement: 10 단계, 이미지 3개 중 2개 Draft Inducer Motor Replacement: 10 단계, 이미지 3개 중 3개
      • Flip over the assembly and use a 1/4-inch socket to remove the three bolts securing the motor bracket to the motor plate.
      • Once the bolts are removed, flip the assembly back over and remove the motor bracket.
      • Once removed, take note of the motor's ground wire, which connects to one of the bracket bolts. Be sure to reconnect it during reassembly.
      댓글 쓰기
    11. Draft Inducer Motor Replacement: 11 단계, 이미지 2개 중 1개 Draft Inducer Motor Replacement: 11 단계, 이미지 2개 중 2개
      • Use a 1/4-inch socket to remove the two bolts securing the motor to the motor plate.
      • Remove the motor bracket.
      댓글 쓰기
    12. Draft Inducer Motor Replacement: 12 단계, 이미지 1개 중 1개
      • When installing the blower fan onto the new motor, be sure that the set screw on the blower fan lines up with the flat edge of the motor's driveshaft.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
43,001 평판
안내서 82개를 작성함
3가이드 댓글
Thanks for the instructions, very helpful.
Do you know the Inducer motor part number?
Selvan Lingam - 답글 공유
Good morning, I need the whole unit ( motor, fan, blower fan, ) etc. This looks like same same unit I have but I can't find a model number for this to make sure I purchase the right one for my unit. I have a carrier weathermaker 8000vs looks exactly like the one here can someone please provide some helpful information thanks.
Joshua Thomas - 답글 공유
Any one know part number for motor for inducer model 22307501
Thanks
Chod - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 92
전체 시간: 28,360
