주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dragon Touch M10X Screen Replacement
필요한 것
    1. Dragon Touch M10X  Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Dragon Touch M10X  Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
      • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
      댓글 쓰기
    2. Dragon Touch M10X  Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
      • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
      댓글 쓰기
    3. Dragon Touch M10X  Screen Replacement: 3 단계, 이미지 2개 중 1개 Dragon Touch M10X  Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Using your hands and the separating tool, remove the back cover from the device.
      댓글 쓰기
    4. Dragon Touch M10X  Screen Replacement: 4 단계, 이미지 2개 중 1개 Dragon Touch M10X  Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Using a J0 phillips head bit, remove the four 1mm screws from the speaker cover. Remove the cover and all four screws.
      댓글 쓰기
    5. Dragon Touch M10X  Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, carefully peel off the yellow tape holding the battery in place.
      댓글 쓰기
    6. Dragon Touch M10X  Screen Replacement: 6 단계, 이미지 1개 중 1개
      • The battery is held onto the surface with a strong epoxy. The battery can be bent easily so extreme care must be taken in removing it from the surface. A plastic opening tool must be used to loosen the battery from the surface.
      • Once it is loose, it may be fully separated by using either your hands or the plastic opening tool.
      댓글 쓰기
    7. Dragon Touch M10X  Screen Replacement: 7 단계, 이미지 2개 중 1개 Dragon Touch M10X  Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Using a J0 phillips head bit unscrew the three 1 mm screws from the motherboard as shown. Remove all three and place them aside.
      댓글 쓰기
    8. Dragon Touch M10X  Screen Replacement: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using a plastic opening tool, lift up the latch that secures the right side of the motherboard to the screen's ribbon cable.
      • Using tweezers remove the screen's ribbon cable from the motherboard.
      댓글 쓰기
    9. Dragon Touch M10X  Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, lift up the latch that secures the left side of the motherboard to the screen's ribbon cable.
      댓글 쓰기
    10. Dragon Touch M10X  Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Completely remove the conjoined battery, speakers, and motherboard from the device.
      댓글 쓰기
    11. Dragon Touch M10X  Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Once all components have been cleared out, you can pry the corners of the device screen away from the LCD panel using a plastic opening tool. Work your way around until it is loose enough to remove.
      댓글 쓰기
    12. Dragon Touch M10X  Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the LCD panel from the device screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Eric Megna
회원 가입일: 03/24/16
333 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-7, Catania Spring 2016 UMass Dartmouth, Team 4-7, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G7
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 38
전체 시간: 4,623
