주요 콘텐츠로 건너뛰기
Dragon Touch Y88X Plus Battery Replacement
필요한 것
  1. Dragon Touch Y88X Plus Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Battery Replacement: 2 단계, 이미지 1/2 Dragon Touch Y88X Plus Battery Replacement: 2 단계, 이미지 2/2
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
    • Carefully peel the old battery from the adhesive using your iFixit pry tool.
    • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
  3. Dragon Touch Y88X Plus Battery Replacement: 3 단계, 이미지 1/2 Dragon Touch Y88X Plus Battery Replacement: 3 단계, 이미지 2/2
    • Use a soldering iron to disconnect each connector individually from the motherboard.
  4. Dragon Touch Y88X Plus Battery Replacement: 4 단계, 이미지 1/1
    • Remove any adhesive from the battery.
    • Remove the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bavly Aziz
회원 가입일: 10/30/23
195 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 12
전체 시간: 95
