주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dremel 4000 Power Cord Replacement
필요한 것
    1. Dremel 4000 Power Cord Replacement, Back Case: 1 단계, 이미지 2개 중 1개 Dremel 4000 Power Cord Replacement, Back Case: 1 단계, 이미지 2개 중 2개
      • Start by removing the housing cap by unscrewing it.
      • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
      • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
      댓글 쓰기
    2. Dremel 4000 Power Cord Replacement: 2 단계, 이미지 1개 중 1개
      • Using your hands, carefully remove hanger from casing.
      댓글 쓰기
    3. Dremel 4000 Power Cord Replacement: 3 단계, 이미지 2개 중 1개 Dremel 4000 Power Cord Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
      • The brush caps are spring loaded.
      댓글 쓰기
    4. Dremel 4000 Power Cord Replacement: 4 단계, 이미지 1개 중 1개
      • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
      댓글 쓰기
    5. Dremel 4000 Power Cord Replacement: 5 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to gently wedge apart the hard plastic threads.
      댓글 쓰기
    6. Dremel 4000 Power Cord Replacement: 6 단계, 이미지 1개 중 1개
      • Use your hands to carefully remove the back casing so that none of the components fall out.
      댓글 쓰기
    1. Dremel 4000 Power Cord Replacement, Power Cord: 7 단계, 이미지 2개 중 1개 Dremel 4000 Power Cord Replacement, Power Cord: 7 단계, 이미지 2개 중 2개
      • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
      댓글 쓰기
    2. Dremel 4000 Power Cord Replacement: 8 단계, 이미지 1개 중 1개
      • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
      댓글 쓰기
    3. Dremel 4000 Power Cord Replacement: 9 단계, 이미지 1개 중 1개
      • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
      • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
      댓글 쓰기
    4. Dremel 4000 Power Cord Replacement: 10 단계, 이미지 1개 중 1개
      • Carefully remove both wires from circuit board with your hands.
      • Take careful note of which side has the black wire and which has the white wire.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
John Cobb
회원 가입일: 01/20/16
1,842 평판
안내서 4개를 작성함
USF Tampa, Team 15-4, Remmell Spring 2016 USF Tampa, Team 15-4, Remmell Spring 2016 회원
USFT-REMMELL-S16S15G4
4 회원들
안내서 17개를 작성함
1가이드 댓글
Super handy guide after my guide dog decided to chew through the cable!
Geoff Palmer - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 91
전체 시간: 7,568
