주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dremel 7300 MiniMite Cordless Collet Replacement
필요한 것
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 1 단계, 이미지 3개 중 1개 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 1 단계, 이미지 3개 중 2개 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 1 단계, 이미지 3개 중 3개
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
    댓글 쓰기
  2. Dremel 7300 MiniMite Cordless Collet Replacement: 2 단계, 이미지 3개 중 1개 Dremel 7300 MiniMite Cordless Collet Replacement: 2 단계, 이미지 3개 중 2개 Dremel 7300 MiniMite Cordless Collet Replacement: 2 단계, 이미지 3개 중 3개
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kat
회원 가입일: 02/10/16
864 평판
안내서 3개를 작성함
USF Tampa, Team 3-4, Sullivan Spring 2016 USF Tampa, Team 3-4, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G4
4 회원들
안내서 4개를 작성함
2가이드 댓글
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - 답글 공유
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 32
전체 시간: 33,133
