주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dremel 8220 Gear Lock Button Replacement
필요한 것
    1. Dremel 8220 Gear Lock Button Replacement, Gear Lock Button: 1 단계, 이미지 1개 중 1개
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      댓글 쓰기
    2. Dremel 8220 Gear Lock Button Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      댓글 쓰기
    3. Dremel 8220 Gear Lock Button Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      댓글 쓰기
    4. Dremel 8220 Gear Lock Button Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      댓글 쓰기
    5. Dremel 8220 Gear Lock Button Replacement: 5 단계, 이미지 3개 중 1개 Dremel 8220 Gear Lock Button Replacement: 5 단계, 이미지 3개 중 2개 Dremel 8220 Gear Lock Button Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the 5 torx screws using a t9 screwdriver head.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      댓글 쓰기
    6. Dremel 8220 Gear Lock Button Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the faulty gear lock button. It should come out of the device easily with no force needed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
connor anisko
회원 가입일: 03/09/16
312 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016 회원
UMASSD-ISAACSON-S16S2G8
3 회원들
안내서 5개를 작성함
3가이드 댓글
I’m assuming the issue I have is a faulty gear-lock button (that, or the locking gear that it restricts when depressed). If so, did you find a replacement button from the manufacturer? In my experience, they rarely offer repair parts themselves.
Robert - 답글 공유
I also don’t understand why there was a flag claiming that this should be broken into separate guides. People aren’t THAT stupid, I hope.
Robert - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 43
전체 시간: 1,395
