주요 콘텐츠로 건너뛰기
DualSense Controller v2 Vibration Motor Replacement
필요한 것
  1. DualSense Controller v2 Vibration Motor Replacement, Unclip the right end of the middle trim: 1 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Unclip the right end of the middle trim: 1 단계, 이미지 2개 중 2개
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Vibration Motor Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 3개 중 3개
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Vibration Motor Replacement, Unclip the left end of the middle trim: 3 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Unclip the left end of the middle trim: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Vibration Motor Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 3개 중 3개
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Vibration Motor Replacement, Remove the middle trim: 5 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Remove the middle trim: 5 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Remove the middle trim: 5 단계, 이미지 3개 중 3개
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Vibration Motor Replacement, Remove the L1 button: 6 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Remove the L1 button: 6 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Remove the L1 button: 6 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Vibration Motor Replacement, Remove the R1 button: 7 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Remove the R1 button: 7 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Remove the R1 button: 7 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Vibration Motor Replacement, Remove the case screws: 8 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Vibration Motor Replacement: 9 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Vibration Motor Replacement, Unclip the rear case: 10 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Unclip the rear case: 10 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Unclip the rear case: 10 단계, 이미지 3개 중 3개
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Vibration Motor Replacement, Remove the rear case: 11 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Remove the rear case: 11 단계, 이미지 2개 중 2개
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Vibration Motor Replacement, Reposition the battery: 12 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Reposition the battery: 12 단계, 이미지 2개 중 2개
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Vibration Motor Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Vibration Motor Replacement, Remove the battery: 14 단계, 이미지 1개 중 1개
    • Remove the battery.
  15. DualSense Controller v2 Vibration Motor Replacement, Remove the lower microphone: 15 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Remove the lower microphone: 15 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Vibration Motor Replacement: 16 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Vibration Motor Replacement, Remove the battery bracket: 17 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Vibration Motor Replacement: 18 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement: 18 단계, 이미지 2개 중 2개
    • Lift the battery bracket off of the motherboard.
  19. DualSense Controller v2 Vibration Motor Replacement, Disconnect the right trigger assembly: 19 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Disconnect the right trigger assembly: 19 단계, 이미지 2개 중 2개
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
  20. DualSense Controller v2 Vibration Motor Replacement: 20 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement: 20 단계, 이미지 2개 중 2개
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
  21. DualSense Controller v2 Vibration Motor Replacement, Disconnect the left trigger assembly: 21 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Disconnect the left trigger assembly: 21 단계, 이미지 2개 중 2개
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Vibration Motor Replacement: 22 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement: 22 단계, 이미지 2개 중 2개
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Vibration Motor Replacement, Disconnect the upper microphone: 23 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Disconnect the upper microphone: 23 단계, 이미지 2개 중 2개
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
  24. DualSense Controller v2 Vibration Motor Replacement, Disconnect the touchpad: 24 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Disconnect the touchpad: 24 단계, 이미지 2개 중 2개
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Vibration Motor Replacement, Lift out the motherboard: 25 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Lift out the motherboard: 25 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Lift out the motherboard: 25 단계, 이미지 3개 중 3개
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
  26. DualSense Controller v2 Vibration Motor Replacement, Desolder the vibration motor wires: 26 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Desolder the vibration motor wires: 26 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Desolder the vibration motor wires: 26 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Flip the motherboard and midframe over to access the red and black vibration motor wires.
    • Use a soldering iron to disconnect the vibration motor wires from the motherboard.
    • To learn how to solder, or to get some helpful tips and tricks, check out our soldering guide.
    • During reassembly, refer to this photo to ensure the wires are soldered back to their correct positions.
  27. DualSense Controller v2 Vibration Motor Replacement, Free the vibration motor wires: 27 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Free the vibration motor wires: 27 단계, 이미지 2개 중 2개
    • Use your spudger to slide the left vibration motor wires out of the midframe.
  28. DualSense Controller v2 Vibration Motor Replacement: 28 단계, 이미지 2개 중 1개 DualSense Controller v2 Vibration Motor Replacement: 28 단계, 이미지 2개 중 2개
    • Use your spudger to slide the right vibration motor wires out of the midframe.
  29. DualSense Controller v2 Vibration Motor Replacement, Remove the left-hand vibration motor: 29 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Remove the left-hand vibration motor: 29 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Remove the left-hand vibration motor: 29 단계, 이미지 3개 중 3개
    • Hold the midframe up to make sure the vibration motor isn't resting on your work surface.
    • Press the flat end of your spudger into the midframe opening against the left-hand vibration motor.
    • Push to release the adhesive securing the vibration motor to the midframe.
    • If the adhesive is too strong, apply heat or 90% isopropyl alcohol to the back of the midframe to soften it.
    • During reassembly, apply some pre-cut adhesive to the new vibration motor to bond it to the midframe.
  30. DualSense Controller v2 Vibration Motor Replacement, Remove the right-hand vibration motor: 30 단계, 이미지 3개 중 1개 DualSense Controller v2 Vibration Motor Replacement, Remove the right-hand vibration motor: 30 단계, 이미지 3개 중 2개 DualSense Controller v2 Vibration Motor Replacement, Remove the right-hand vibration motor: 30 단계, 이미지 3개 중 3개
    • Press the flat end of your spudger into the midframe opening against the right-hand vibration motor.
결론
작성자
1다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
92,681 평판
안내서 290개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 48
지난 30일: 194
전체 시간: 4,406
