주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DualShock 2 Disassembly
필요한 것
  1. DualShock 2 Disassembly, DualShock 2 Disassembly: 1 단계, 이미지 2개 중 1개 DualShock 2 Disassembly, DualShock 2 Disassembly: 1 단계, 이미지 2개 중 2개
    • First, check that the connection port of your controller (whether wireless or not) has all the pins.
    • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
    댓글 쓰기
  2. DualShock 2 Disassembly: 2 단계, 이미지 2개 중 1개 DualShock 2 Disassembly: 2 단계, 이미지 2개 중 2개
    • Flip Over Controller and remove all 6 screws from the bottom of the controller.
    댓글 쓰기
  3. DualShock 2 Disassembly: 3 단계, 이미지 2개 중 1개 DualShock 2 Disassembly: 3 단계, 이미지 2개 중 2개
    • Once the screws are removed, carefully pry the controller open with your hands.
    • Remove the screw holding the circuit board in place.
    댓글 쓰기
  4. DualShock 2 Disassembly: 4 단계, 이미지 1개 중 1개
    • Carefully remove the circuit board from the front cover of the controller.
    댓글 쓰기
  5. DualShock 2 Disassembly: 5 단계, 이미지 1개 중 1개
    • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
    댓글 쓰기
  6. DualShock 2 Disassembly: 6 단계, 이미지 1개 중 1개
    • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
    댓글 쓰기
  7. DualShock 2 Disassembly: 7 단계, 이미지 1개 중 1개
    • Check the connection of the flexible trigger board to the main circuit board of your controller.
    댓글 쓰기
  8. DualShock 2 Disassembly: 8 단계, 이미지 1개 중 1개
    • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
    댓글 쓰기
  9. DualShock 2 Disassembly: 9 단계, 이미지 1개 중 1개
    • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 48명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Peder Hertel
회원 가입일: 09/29/15
1,503 평판
안내서 1개를 작성함
Cal Poly, Team 17-5, Green Fall 2015 Cal Poly, Team 17-5, Green Fall 2015 회원
CPSU-GREEN-F15S17G5
4 회원들
안내서 12개를 작성함
7가이드 댓글
Dualshock 2 controllers, model A and H, are having 8 pins, not 9. Your first Step is false and rarely wires are the cause of the problem.
Eva Langley - 답글 공유
No my Dual-shock 2 controller has 9 pins so you are wrong he is right man.
Adam Bolyard - 답글 공유
Eva Langley is correct, some of these controllers have only 8 pins, not 9. I myself can conformed this because I just recently opened one of two brand new fresh out of the box Sony original equipment controllers that I purchased (for a little less than $10 a piece) during a clearance sale at my local Sears just before they went out of business. So Eva is NOT wrong. I still have the second one still in the box and before anyone ask, I don’t won’t to sale. I purchased them because I have had both my original controllers go out after they were sitting up for a few years without use. My game units are very well taken care of but the controllers of the PS2 just stopped working and finding a definitive answer to why this happens is STILL very elusive in 2019.
byordsilp - 답글 공유
After opening one of these, the R2 and L2 buttons don't feel right, is there a way to fix this?
Fridtjof Riibe - 답글 공유
Try to put R2 and L2 after you close the shell. The buttons have clips that hold on position after you insert them .
Alex SC - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 197
지난 30일: 970
전체 시간: 87,017
