주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DualShock 3 Front Shell Cover Replacement
필요한 것
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: 1 단계, 이미지 2개 중 1개 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: 1 단계, 이미지 2개 중 2개
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
    댓글 쓰기
  2. DualShock 3 Front Shell Cover Replacement: 2 단계, 이미지 3개 중 1개 DualShock 3 Front Shell Cover Replacement: 2 단계, 이미지 3개 중 2개 DualShock 3 Front Shell Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
    댓글 쓰기
  3. DualShock 3 Front Shell Cover Replacement: 3 단계, 이미지 2개 중 1개 DualShock 3 Front Shell Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
    댓글 쓰기
  4. DualShock 3 Front Shell Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the rear cover off of the controller to expose the interior.
    댓글 쓰기
  5. DualShock 3 Front Shell Cover Replacement: 5 단계, 이미지 3개 중 1개 DualShock 3 Front Shell Cover Replacement: 5 단계, 이미지 3개 중 2개 DualShock 3 Front Shell Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
    댓글 쓰기
  6. DualShock 3 Front Shell Cover Replacement: 6 단계, 이미지 3개 중 1개 DualShock 3 Front Shell Cover Replacement: 6 단계, 이미지 3개 중 2개 DualShock 3 Front Shell Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
    댓글 쓰기
  7. DualShock 3 Front Shell Cover Replacement: 7 단계, 이미지 2개 중 1개 DualShock 3 Front Shell Cover Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
    댓글 쓰기
  8. DualShock 3 Front Shell Cover Replacement: 8 단계, 이미지 1개 중 1개
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Joseph Wambui
회원 가입일: 07/09/21
253 평판
안내서 1개를 작성함
York University, Team 1-28, O'Regan Fall 2021 York University, Team 1-28, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S1G28
1 회원
안내서 3개를 작성함
1가이드 댓글
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 55
지난 30일: 243
전체 시간: 7,846
