주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DualShock 4 CUH-ZCT2 Rear Panel Replacement
필요한 것
  1. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel screws: 1 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel screws: 1 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
    댓글 쓰기
  2. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Separate the rear panel: 2 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Separate the rear panel: 2 단계, 이미지 2개 중 2개
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
    댓글 쓰기
  3. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 1개 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 2개 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 3개
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
    댓글 쓰기
  4. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel: 4 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel: 4 단계, 이미지 2개 중 2개
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
    댓글 쓰기
  5. DualShock 4 CUH-ZCT2 Rear Panel Replacement: 5 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Rear Panel Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
99,427 평판
안내서 290개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 34
지난 30일: 176
전체 시간: 6,346
