주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson Ball Animal Hose Replacement
필요한 것
    1. Dyson Ball Animal Hose Replacement, Hose: 1 단계, 이미지 2개 중 1개 Dyson Ball Animal Hose Replacement, Hose: 1 단계, 이미지 2개 중 2개
      • Turn off power and unplug the vacuum, then turn the vacuum to look at the hose.
      댓글 쓰기
    2. Dyson Ball Animal Hose Replacement: 2 단계, 이미지 2개 중 1개 Dyson Ball Animal Hose Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the red dial counterclockwise and pull up on the wand to remove.
      댓글 쓰기
    3. Dyson Ball Animal Hose Replacement: 3 단계, 이미지 3개 중 1개 Dyson Ball Animal Hose Replacement: 3 단계, 이미지 3개 중 2개 Dyson Ball Animal Hose Replacement: 3 단계, 이미지 3개 중 3개
      • Press in the red button where the wand attaches to the hose and pull apart.
      댓글 쓰기
    4. Dyson Ball Animal Hose Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the main canister by pressing the red release button and pulling up and away.
      댓글 쓰기
    5. Dyson Ball Animal Hose Replacement: 5 단계, 이미지 3개 중 1개 Dyson Ball Animal Hose Replacement: 5 단계, 이미지 3개 중 2개 Dyson Ball Animal Hose Replacement: 5 단계, 이미지 3개 중 3개
      • Grip the base of the hose so your thumb reaches around to press the red tab shown.
      • Push the red tab at towards the hose while pulling the hose upwards.
      • With some wiggling, it will come out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mitchell Klein
회원 가입일: 04/23/17
911 평판
안내서 2개를 작성함
10가이드 댓글
I used the hose and attachments on my ball animal + up13 and after removal of attachment and stowing the hose to the handle assy. , I can not get the vacumm to stop sucking from the top of the handle? I’ve attempted reading the owners manual (which is not user friendly) and also watched Youtube demonstrations with no luck. This has been two days of struggling with no success???
james gaspard - 답글 공유
The suction is diverted to the hose when the machine is upright. Stand behind the machine, pull the handle towards you and the transfer valve automatically diverts the suction to the brush head. Put it back into the upright position and suction automatically diverts to the rear hose.
mike.vardy - 답글 공유
can anyone show me a picture of the transfer valve? I think it is not going into position when I try to use the wand.
Rita & Chuck Mergen - 답글 공유
it looks like the wand has a round plastic device in middle is this correct? i have taken the wand out of the hose and the hose has suction but when all goes back together and turn on the hand held wand device has no suction
woody jones - 답글 공유
Awesome! Worked like a charm. I had sucked up one of the cat's toys. I was able to remove the little toy and the hose works again.
Thank you!
jboyd5322 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 110
지난 30일: 530
전체 시간: 149,110
