주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson DC14 Power Switch Replacement
필요한 것
  1. Dyson DC14 Power Switch Replacement, Power Switch: 1 단계, 이미지 2개 중 1개 Dyson DC14 Power Switch Replacement, Power Switch: 1 단계, 이미지 2개 중 2개
    • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
    • Remove the canister from the vacuum.
    • Disconnect the telescopic vacuum wand.
    • Remove the two T15 Torx screws securing the switch cover to the vacuum.
    댓글 쓰기
  2. Dyson DC14 Power Switch Replacement: 2 단계, 이미지 2개 중 1개 Dyson DC14 Power Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Push outward on the two plastic clips that secure the switch cover to the vacuum.
    댓글 쓰기
  3. Dyson DC14 Power Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the switch cover from the vacuum.
    • The purple switch button may separate from the rest of the switch cover.
    댓글 쓰기
  4. Dyson DC14 Power Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
    • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
    • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Zachary
회원 가입일: 10/06/12
318 평판
안내서 1개를 작성함
Cal Poly, Team 3-22, Amido Fall 2012 Cal Poly, Team 3-22, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G22
4 회원들
안내서 8개를 작성함
10가이드 댓글
Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!
Tim Swift - 답글 공유
The comment I listed below is not mine. I copied it from a Mr. Tim Swift who wrote it on 06/28/2015. Had I not have seen his comment, I would have said the exact same thing.
I have only one other thing to say......AWESOME!!
Bob Williams
robertvwilliams@comcast.net
"Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!"
Robert Williams - 답글 공유
I replaced my power switch. Easy! $15 part!
brdurham - 답글 공유
Thanks from a 70 year old non-mechanical female with no torque wrench. I followed this tutorial a few months ago and found that my switch had simply come undone and I reinserted it but couldn't attach orange thing back cause switch kept slipping loose. I taped it up around switch so I wouldn't get electrocuted when turning on. Has worked fine til now, and I suppose my switch has finally failed, so I'm ordering new one. This Dyson was a refurbished one I got fairly cheap (for a Dyson) 12 years ago! SO, THANKS MUCH!!
Queenie - 답글 공유
Brilliant and saved me over £100 which is the cost of a Dyson engineer to attend plus switch. Name a charity.
Tariq Rafique - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 63
전체 시간: 39,494
