주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson DC39 Origin Ball Wheels Replacement
필요한 것
    1. Dyson DC39 Origin Ball Wheels Replacement, Bin: 1 단계, 이미지 3개 중 1개 Dyson DC39 Origin Ball Wheels Replacement, Bin: 1 단계, 이미지 3개 중 2개 Dyson DC39 Origin Ball Wheels Replacement, Bin: 1 단계, 이미지 3개 중 3개
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      댓글 쓰기
    1. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 2 단계, 이미지 3개 중 1개 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 2 단계, 이미지 3개 중 2개 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 2 단계, 이미지 3개 중 3개
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      댓글 쓰기
    2. Dyson DC39 Origin Ball Wheels Replacement: 3 단계, 이미지 3개 중 1개 Dyson DC39 Origin Ball Wheels Replacement: 3 단계, 이미지 3개 중 2개 Dyson DC39 Origin Ball Wheels Replacement: 3 단계, 이미지 3개 중 3개
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      댓글 쓰기
    1. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: 4 단계, 이미지 2개 중 1개 Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: 4 단계, 이미지 2개 중 2개
      • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
      • There is one screw located at the center of each wheel.
      댓글 쓰기
    2. Dyson DC39 Origin Ball Wheels Replacement: 5 단계, 이미지 3개 중 1개 Dyson DC39 Origin Ball Wheels Replacement: 5 단계, 이미지 3개 중 2개 Dyson DC39 Origin Ball Wheels Replacement: 5 단계, 이미지 3개 중 3개
      • Pull the wheel away from the main body of the device.
      • This may require a lot of force. The plastic wheel may bend slightly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael Hutcheson
회원 가입일: 04/26/17
312 평판
안내서 2개를 작성함
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G6
3 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 34
전체 시간: 2,673
